troubled idi
Old Jan 8, 2026 | 08:53 PM
93f350dump's Avatar
93f350dump
3rd Gear
troubled idi
Purchased my 93 f350 w/7.3idi, auto trans from original owner 19 yrs ago. Has been trouble free until recently. In overdrive around 45 mph engine acted like it had a bad miss, w/170k miles figured I'd replace injector pump (rebuilt from stanadyne) Motorcraft injectors & glow plugs, fuel pump & filter. Ran normal until last week, slow down to stop and engine would cause truck to lunge forward and run as if it were loading up, had to put it in neutral to stop, then while in neutral it idled normal, put in drive idle increased without stepping on accelerator and still loading up until accelerated over 800 rpm's then ran normal. Wondering if any has had issues like this and what causes it. Thank you.
Old Jan 9, 2026 | 09:07 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Sounds like the torque converter is failing; feeling like and engine miss part and then it isn't unlocking; the wanting to keep pushing the truck forward at idle part.
Old Jan 10, 2026 | 11:43 AM
tjc transport's Avatar
tjc transport
i ain't rite
check trans fluid level first, low fluid level will keep the converter locked
Old Jan 10, 2026 | 09:53 PM
93f350dump's Avatar
93f350dump
3rd Gear
Thank you, that is something I wouldn't have expected, will check the level though.
Old Jan 14, 2026 | 04:22 PM
93f350dump's Avatar
93f350dump
3rd Gear
Haven't had a chance to work on it, ordered the throttle position sensor so after getting it installed I'll be able to run it and check the trans fluid level. Will sent info when complete.
Willey2
Dec 31, 2024 04:17 PM
818rider
21
Apr 9, 2024 06:04 PM
batchman
Dec 30, 2015 08:14 AM
1970 Boss 302
Dec 15, 2007 11:08 PM
96CoolCrew
Oct 1, 2003 05:15 PM
