91 IDI injection pump questions
Old Dec 29, 2024 | 10:43 AM
Willey2's Avatar
Willey2
Trailering
‘91 7.3 IDI has had a history of fuel delivery problems. Fail to restart after fueling, then start after overnight. ( transfer switch issue?), slow start, multiple attempts after sitting for a week (recent issue) then driving down a steep grade just quit. Followed by replace filter and bleed, glow plugs and injectors were working fine just prior. Pulled drivers side return to injector pump, flowed fuel but not excessively. Attempts at bleeding injectors not successful. Sounds like a IP failure but no prior indications, smoking, low power etc. Over 200k miles. No prior replacement. Better tests? Might also see my post on removing rear tank tank and apparatus. Checking air infiltration as well. Many thanks on experience.
Old Dec 29, 2024 | 12:29 PM
tjc transport's Avatar
tjc transport
i ain't rite
if you know for sure the injector pump and injectors have over 200k miles on them, they are way overdue for replacement.
Old Dec 29, 2024 | 01:56 PM
Willey2's Avatar
Willey2
Trailering
Likely yes
Glow plugs, controller and injectors replaced, more age than mileage on them. I’ll run down every issue from the tanks forward, then the IP. Everything else that bolts to this truck has been replaced, some more than once. Thanks.
Old Dec 30, 2024 | 09:09 AM
WCMtn1990's Avatar
WCMtn1990
Although I haven't had it happen to me I have always read that one of the classic symptoms of a failing IP was no-start when the pump is hot--as in driving fine for a while then make a brief stop like refueling and the engine won't start until the pump has cooled down. Avoid Pensacola diesel when buying a new IP.
Old Dec 30, 2024 | 11:52 AM
tjc transport
i ain't rite
Agreed. The recommended pump exchange services are r&d, and moose.
when it will not hot start, pouring cool NOT ICE COLD water over the pump usually works to get it fired back up
Old Dec 30, 2024 | 05:47 PM
Willey2's Avatar
Willey2
Trailering
IP rebuild
The references to known quality rebuilders is appreciated. Thank you.
Old Dec 31, 2024 | 01:41 PM
bulletpruf's Avatar
bulletpruf
This ^^^^
Old Dec 31, 2024 | 04:17 PM
Willey2's Avatar
Willey2
Trailering
IP REPLACEMENT
With the Wondertruck, perform regular maintenance, but run to failure. Snow plow and dump insert. Doesn’t go anywhere if not loaded both ways. Thanks for all the rebuilders and suppliers info.
Mike94f350
20
Dec 30, 2024 09:26 AM
Andrew James
17
Dec 11, 2017 05:41 AM
1990f3507.3idi
25
Nov 19, 2017 10:02 AM
183beast
Dec 3, 2012 11:47 PM
dyoungen
Jun 11, 2012 08:51 AM
