Sponsored by: Real Truck
Shift cable help!
Old Jan 7, 2026 | 12:37 PM
nate_coburn's Avatar
nate_coburn
2nd Gear
Shift cable help!
Hello so recently I broke the drift pin inside the transmission pan while attempting to replace the arm that the cable attaches to. While yanking on the nut I broke the drift pin and then later broke the shaft that comes out of the pan for the arm. Just replaced everything and put back all nice and it all moves how it should till you put the cable on and start the truck. Once you go to shift through the different gears it stops you right at reverse. Need some help on where to look I am stumped. Thank you all! Truck is a 2014 f-550
digr
1997 - 2003 F150
Oct 15, 2023 09:52 PM
2manytickets
Aug 27, 2017 12:35 PM
Daviddc114
Jul 30, 2009 10:49 AM
