Trailer TPMS not reading forward axle
Old Jan 4, 2026 | 08:39 AM
jmca94's Avatar
jmca94
2nd Gear
I have an RV with ford rear camera and TPMS, the RV Trailer TPMS not reading forward axle was previously pulled with a 24 F350 and now I currently pull it with a 26 F350. The rear camera works, both tires on the rear trailer axle are reading temp and pressure, but the forward axle is not reading temp or pressure. These should be compatible right? Any suggestions on why I am not getting a reading?
Old Jan 4, 2026 | 09:20 AM
HRTKD's Avatar
HRTKD
Have you tried the relearn process?
As near as I can tell, the TPMS settings (sensor addresses, sensor location, min pressure) are stored in the receiver that is installed under the trailer. So it should have transferred just fine to your new truck.
Old Jan 4, 2026 | 10:55 AM
jmca94's Avatar
jmca94
2nd Gear
Relearn process
I am going to give the relearn a try and see if that fixes it.
island eddie
All Things Towing
19
Mar 21, 2022 09:52 AM
fmf15e
Jun 22, 2017 03:22 PM
billyjoe
All Things Towing
Oct 23, 2003 04:22 PM
randallc
All Things Towing
Jun 24, 2003 09:00 PM
