Alternator or Voltage regulator
Old Jan 4, 2026 | 01:48 AM
Obscure69's Avatar
Obscure69
I was out driving the other day, running some errands, when I noticed that my pickup didn’t have the normal “pepp” in the starter. I suspected it wasn’t charging, but I didn’t have anything with me to confirm. I made it home, but when I tried starting it again, it wouldn’t turn over. I checked the battery, and it was at about 9 volts. I put it on charge over night, and she started right back up, but checking the voltage it only reads about 12.5 volts and it’s declining as it’s running.
now, how do I check it it’s the alternator or the voltage regulator, or something else?
Old Jan 4, 2026 | 11:15 AM
JimsRebel's Avatar
JimsRebel
Here's good info on doing a full field test from 1TonBaseCamp
https://www.ford-trucks.com/forums/1...regulator.html
If the alternator is bad you should consider doing a 3G conversion. It might be cheaper to get a brand new 3G alternator than a very old 1G alternator that's been rebuilt so many times. Be careful when shopping as some are "compatible" with a 1G, but not really a 1G alternator.
I got my 3G at a junkyard. But if I was buying new I would research a small case 95 amp 3G alternator. Seems more practical for most folks. The junkyard did not have any of these when I was buying mine. I am not sure if the small case 95 amp cost more.
The large case would be available anywhere, so you could do a parking lot repair, compared to something that needs to be shipped. I am not a fan of one wire alternators, plus a replacement would require shipping.
The original 1G is a solid and reliable alternator. But the 3G is a giant leap forward in technology and power output. It really just comes down to what you needs are, or what your future needs will be.
Jim
Old Jan 4, 2026 | 03:47 PM
BobbyFord's Avatar
BobbyFord
FWIW, a charging system will not charge a dead/junk battery.
Pull the plug off of the regulator, jump the A and F terminals, start the engine and measure voltage at the battery. This jump method bypasses the regulator and the alt should produce wide open voltage. This will let you know if the alternator is good.
You may still need further investigation but this will eliminate a bad alternator.
Old Jan 11, 2026 | 03:19 AM
Obscure69's Avatar
Obscure69
It seems that the alternator is not putting out any voltage. It is over 50 years old, so maybe no wonder… the regulator has been replaced at some point in the past, but who knows when. I’m sort of infavor of keeping things as original as possible (also a stingy booger), so I am going to first try and replace the brushes and see if that wakes the alternator. If that doesn’t work, then I’ll look into replacement with something else.
Old Jan 11, 2026 | 09:22 AM
JimsRebel's Avatar
JimsRebel
That's actually what I would do, if I didn't need a higher amperage output.
I prefer to rebuild my own stuff, as then I know the history. Buying overhaul or rebuilt often means just getting someone else headaches. The overhaul part might only have new brushes swap in, which is something you can do yourself.
Thoughts:
If the brass part, where the brushes ride, is worn, you won't get full life out of the rebuild, but I would still run it as is.
Look for rub marks, rotor to stator. Rubbing means it wont work.
After you're done, take it to an auto parts store and have it tested. This will tell you if all the diodes are good.
From a cost point of view, I would also stop at brushes, unless you want to keep original parts on your truck.
Good luck, Jim
bnokes01
17
May 4, 2024 10:29 PM
FarmTrucks
Feb 14, 2024 10:01 PM
maximumd93
Mar 11, 2013 09:52 AM
390
Electrical Systems/Wiring
Nov 25, 2006 12:05 AM
farmnfly
Nov 12, 2006 05:23 PM
