Electric choke issues
Old Dec 30, 2025 | 08:31 PM
Ike_1978's Avatar
Ike_1978
3rd Gear
Hello, Ike here with a 78 2wd Camper special. Running a 400 with a Holley 2bbl. I do not have the manual choke connected, and I have attempted to install an electronic choke, however the instructions aren't as simple as I'd like. I can not even get past the first few steps. I have been able to remove the old linkage, however there are some issues with installing the fast idle cam. I attempted several times and gave up and put on the old non-working choke on the truck. Any advice would be greatly appreciated.
Old Dec 30, 2025 | 08:40 PM
440 sixpack's Avatar
440 sixpack
I've done a half dozen or so and I didn't think it was that hard. the instructions should walk you through it as long as you have a standard Holley.
You don't have a truck version with a governor or something do you? that might be a problem.
Old Dec 30, 2025 | 08:44 PM
Viper Pilot's Avatar
Viper Pilot
Might help:
Old Dec 30, 2025 | 09:07 PM
Ike_1978's Avatar
Ike_1978
3rd Gear
Choke issues
Thanks for the responses so far. No governor seen. I have seen that video. I feel like the The shaft of my Holly carb was not that long, as in the video and I could not get it on at all. I even engaged the accelerator slightly to lengthen the arm and it still would not attach. I did score a 4bbl carb with an electric choke, however reading the truck may not be as "responsive" as it is now. I feel that she has a lot of pep when I accelerate as it is. I also need a new intake.. so the saga continues. A lot of cold weather feathering of the gas pedal as I am the choke on a 20 degree day.. lol. Thanks again.
Old Dec 31, 2025 | 03:55 PM
440 sixpack
I'm not really sure what you have going. but if your 4V is a smaller CFM and it's set up right you can install it on your 2V manifold with a simple 4x2 adapter. it's not ideal but it does work people have been doing it for decades.
lucky_strike
Sep 21, 2010 05:35 PM
MER
Jan 29, 2008 06:49 PM
ramtoo
Nov 8, 2005 05:46 PM
HotWhlz85
Nov 4, 2002 02:21 PM
