choke
Old Nov 3, 2005 | 10:04 AM
ramtoo's Avatar
ramtoo
Question choke
Hi group been a while. Well the weather in texas is getting a little cool and my manual choke needs to be adjusted! Can anyone help the little screw that works the lower butterflies how is this steup? Is the tip of the screw to touch the cam or is it to be off the cam?
Old Nov 3, 2005 | 11:16 AM
1975Ford's Avatar
1975Ford
I find adjusting the choke on carb. is best done early in the morning.
Loosen the three screws on choke housing, and turn the choke, till the choke flap on carburator is fully open, then back the choke till the choke flap is almost closed. Tighten the three screws for the choke.
Old Nov 3, 2005 | 12:18 PM
ramtoo's Avatar
ramtoo
MANUAL CHOKE
But thanks for trying
Old Nov 3, 2005 | 12:33 PM
1975Ford's Avatar
1975Ford
When you say manual choke, It's not the electric choke.
Are you saying it's the pull cable choke.
Old Nov 3, 2005 | 01:37 PM
ramtoo's Avatar
ramtoo
yes pull cable its in a 68 F100 360 cid 3 speed on the floor now
Old Nov 3, 2005 | 01:52 PM
bertha66's Avatar
bertha66
When warm the screw does not need to touch the cam, but when you pull it out it will open up the gas and up the idle.
Old Nov 8, 2005 | 05:46 PM
Tissueboxracer's Avatar
Tissueboxracer
I have no idea, i never use it, as I also have a manual choke .....thats stuck.
yabadaba
May 15, 2016 10:29 AM
obwan
Feb 16, 2016 07:02 PM
Buyerz
Sep 20, 2015 06:15 AM
WhoaFiveOh
Sep 5, 2013 05:49 AM
amory
Jan 19, 2009 05:36 PM
