408 heads/ build
Old Dec 30, 2025 | 11:03 AM
pdhulteng's Avatar
pdhulteng
408 heads/ build
Started the assembly of the 408. First engine I have done in 40 years😳. I haven’t missed been watching lots of you tube videos and any CONSTRUCTIVE help would be appreciated. I have a set of Edelbrock heads that I have been working on that will go on it.
Old Dec 30, 2025 | 02:20 PM
SDDL-UP's Avatar
SDDL-UP
Looking good man! And good job on the heads - the Windsor needs all the help it can get, especially at 408C.I.
Old Dec 30, 2025 | 05:08 PM
cougrrcj's Avatar
cougrrcj
Which Edelbrock heads are you starting with??? That will make a difference.
Just for reference:
https://www.carbdford.com/tech/flowdata.htm
I had used a pair of professionally-ported iron World Windsor Seniors on my 9.4:1 emission-test-legal(!) 393W.
Then when it got rebuilt into a 11.1:1 395W, I used a set of as-cast Roush 200s and ill-port-matching BBK 1-5/8 shorty headers - Dynoed at 506hp @ 6000 with a mild hydraulic roller (.544/.544" 276/282adv, 224/230 @ .050). The as-cast Roush200s flowed less than my old iron Worlds!
I was not impressed with the Roush, so on went a pair of Fox Lake Racing CNC'd Edelbrocks and proper-port-matching 1-7/8 longtubes. Gain of almost 100hp/45tq over the Roush/BBKs!!!!
Old Dec 30, 2025 | 08:27 PM
1Butcher's Avatar
1Butcher
I am starting my 408 build this week too. I suspect I will not be done for a few months.
I elected to go with 185 AFR Renegades. I drilled the head to accept the wider 3" bolt spacing. I am also building long tube headers.
I elected to go with Mahle forged pistons and should end up with about 9 to 1 compression. I am running a Kenne Bell supercharger and should keep the 8psi I have now [on my 351w]. Custom roller cam and a factory roller block.
My purpose is for towing, what is your goal?
Old Jan 1, 2026 | 03:22 AM
pdhulteng's Avatar
pdhulteng
Just for reference:
I am using Edelbrock Performers
Hartwig
May 19, 2022 07:10 AM
nails023
23
Jul 3, 2018 11:14 AM
1979 Ford
South Dakota Chapter
122
Aug 1, 2017 07:19 AM
capelo
23
Apr 15, 2014 04:21 PM
robjs111
Ford Truck Parts for Sale
Aug 20, 2013 08:43 PM
