I have a 2000 xlt 6.8 v10 excursion. I recently ran into a issue with my work trailer. Long story short is I needed a new wire harness. After wiring it all up I have break and blinkers but no running lights. I do not understand why it's acting like this. I have checked the fuse under the hood. I do have a license plate light out I don't know if it's ran through that or not. Any suggestions on why I have blinkers and breaks but no running lights would be appreciated.
I always drill a hole and bolt a White Wire to the Bumper of the truck,
and do the same for the Trailer's frame.
use a Bullet push/pull connector to complete the circuit....
ball hitches "are not a ground", most have grease on them anyway.
Trailer wiring issues are normally a ground problem! I always tell people to start with the ground wires first then check fuses. A tester is awesome and helpful. Good luck 👍
so it's not the trailer itself. I hooked it up to my f250 and everything worked, so its something wrong with the x it's self.
this is my plan if attack today, as i figired out its not the trailer and is the truck as i hooked this up to f250 and everything worked. Which would lead me to belive its the hookup on the excursion.
