Engine swap
Old Dec 27, 2025 | 11:28 AM
TylerSta's Avatar
TylerSta
Engine swap
I have a f100 that had a FE. It needs a new engine and I have a guy with both a FE but also an Inline 300. Depending on the condition of the FE I might want to put the 300 in instead. I was wondering what all would have to change to accommodate the 300
Old Dec 27, 2025 | 12:35 PM
85e150's Avatar
85e150
Bell housing, exhaust, possibly cooling, mounts--l think it's the same perches but they have to be moved. Carb linkage and possibly fuel lines in engine compartment.
All FE motors are not created equal. Check those engines carefully.
Old Dec 27, 2025 | 06:35 PM
1browski's Avatar
1browski
Did your f100 have a manual or automatic tranny?
Old Dec 27, 2025 | 06:36 PM
TylerSta's Avatar
TylerSta
manuel. I’m also considering a 361 FT. It only has 18000 miles on it and runs good. I don’t know what I would have to do to it though
Old Dec 27, 2025 | 06:58 PM
85e150's Avatar
85e150
Forget the 361FT. Mounting is different and there are several differences between it and the FE that will cause issues with a swap.
Old Dec 29, 2025 | 01:41 PM
fe390pc's Avatar
fe390pc
The easiest is to go with the FE. The 300 is a great engine, but the amount of parts needed for the swap is a lot unless you can find a donor truck. Just my two cents. Good luck either way you go. Also stay away from the FT as it is totally different!
Old Dec 29, 2025 | 04:35 PM
TylerSta's Avatar
TylerSta
I think I have to go with the FT. From what I can find, I’ll have everything I need on the parts truck and it will be cheaper that way
Old Jan 3, 2026 | 08:03 PM
fe390pc's Avatar
fe390pc
You should look at this very carefully. The FT engine shares a few common parts, but they are few. The FT has a different style crank with very different sizes. You will need the trans, bell housing, mounts, exhaust manifolds. You will need to retain the FT dizzy as well which is a not great. I still think going with the FE is your best bet!
Old Jan 3, 2026 | 08:13 PM
TylerSta's Avatar
TylerSta
I have a whole doner truck to pull from. I think I would be able to do it with the FT a lot cheaper. You can get a adapter bushing for the FE dizzy
Old Jan 4, 2026 | 10:39 AM
fe390pc's Avatar
fe390pc
Ok, but remember that the FT engine mounts off the front cover and rear bell housing. Meaning you will need to add those cross members from the donor truck.
Old Jan 4, 2026 | 08:28 PM
85e150's Avatar
85e150
Balance. Did you read about balance?
Your FE front cover won't fit either.
Your front engine accessory drive must be FE or FT, no mixing.
You're headed to the scrap yard with this......
halfwhit
Aug 10, 2025 09:36 AM
mudboggin
Nov 29, 2023 07:51 PM
65_Guy
Oct 4, 2010 02:46 PM
dadynobuks
Apr 24, 2007 09:11 AM
