351w Swap
Old Dec 31, 2025 | 03:01 PM
  #31
Hit Man X's Avatar
Hit Man X
I too recollect early Lightning were flat tappet, but equipped with the F4TE block I do believe
Ford was probably using up whatever was left in the parts bin, makes sense from financial standpoint
Swear GM did the same with TBI trucks
Old Dec 31, 2025 | 03:05 PM
  #32
90project5.0's Avatar
90project5.0
So one would have to search for a F4 block with F4 cam? Anything else to distinguish without tearing down?
Old Dec 31, 2025 | 03:12 PM
  #33
Hit Man X's Avatar
Hit Man X
No clue change over, I would assume later 94. Yet, to assume makes an *** out of u and me
My 05/88 302 was not drilled, nor tapped, 'nubs' there. Pal's 11/88 302, 89MY, as ready to rock.
Both the crapola flat tappet, peanut camshaft. The later the better
Old Dec 31, 2025 | 03:15 PM
  #34
90project5.0
I have a hair of making an *** of myself, no need for help! Just ask the wife haha! Everyone always talks about getting the F4 casting so it was a roller. That’s why I’m just going to boost what I have, I already know!
Old Dec 31, 2025 | 03:18 PM
  #35
Hit Man X's Avatar
Hit Man X
My F4TE block was roller cam when acquired, I swear came from a 95MY truck. Been years, I picked it up in AR when had condo on Lake Hamilton.
Old Dec 31, 2025 | 03:23 PM
  #36
rla2005's Avatar
rla2005
We have seen a few instances of 1995 model year truck/van engines with F4 blocks and still have flat tappet cams on this forum over the years.
Old Dec 31, 2025 | 03:39 PM
  #37
Hit Man X's Avatar
Hit Man X
Wow! News to me, glad to know.
Old Dec 31, 2025 | 03:53 PM
  #38
90project5.0
Damned if you do, damned if you don’t. In case I have to, any 90+ block and no matter what plan on top end roller stuff. I’m a plan for the worst person.
Old Dec 31, 2025 | 04:06 PM
  #39
cougrrcj's Avatar
cougrrcj
If your block has the raised 'nub' above the #2 and #4 cam bearing, you should be good to go. Easy to drill/tap for the 1/4-20 spider hold-down bolts. Roller cam motors also had the top surface of the lifter bores machined flat for the 'dogbones'. The spider/dogbones and lifters are the same as a roller 5.0.
For 'better' stock SBF head shopping at your local pick-a-part, 5.0 Ford Explorers/Mercury Mountaineer used either the GT40 heads 1994-1997.5, and GT40Ps from '97.5-2002. BUT they will have 7/16 head bolt holes. 351Ws used 1/2" head bolts. The 5.0 heads can bee drilled to accept 1/2" bolts - just a few bucks for your machinist unless you have a good drill press.
Cams, the stock roller cam is only around .444 lift and a 195-200° duration at .050. The 5.0HO mustang cam had that same anemic .444 lift, but a 210° duration at .050.
Old Dec 31, 2025 | 05:30 PM
  #40
My4Fordtrucks's Avatar
My4Fordtrucks
You kind of lost me. Just like the 302 in your truck that doesn’t mean it isn’t a roller ready block with a flat tappet camshaft.
Same here. My F4TE engine was out of a ‘94 E-150 conversion van.
Old Dec 31, 2025 | 05:41 PM
  #41
fishfreak101's Avatar
fishfreak101
Are the lifters roller? F4 is a roller motor.
I doubt someone put link lifters, but it’s possible.
yeah unfortunately is most definitely a roller block with a flat tappet tappet cam and lifters so plans for this engine are definitely gonna change
Old Dec 31, 2025 | 05:48 PM
  #42
90project5.0
what I meant was I was under the impression that all F4 blocks had a roller cam installed, factory. I didn’t know that any had flat tappet. Before working on my 302, I had been toying the idea of an F4TE assuming it was a roller motor (would have lifters, spider and dog bones).
Old Dec 31, 2025 | 06:56 PM
  #43
1Butcher's Avatar
1Butcher
I would not trust me, but I have heard/read that some of the early roller blocks had flat tappet cams. The blocks had the holes to mount the spider.
Old Dec 31, 2025 | 10:06 PM
  #44
90project5.0
My 90 (302) is tapped for them. I didn’t go roller due to cost. I was able to get more done for less than the cost of just the roller cam and lifters. I don’t regret it, but it’s not permanent either.
Old Jan 1, 2026 | 03:41 PM
  #45
My4Fordtrucks
So how is buying two camshafts cheaper?
