351w Swap
Old Dec 27, 2025 | 09:18 AM
fishfreak101's Avatar
fishfreak101
Originally Posted by rwfid
I was under the impression it is a 1988 300-6 truck. I didn't realize they ran the E4OD behind them. Transmission type really only matters to people who like to consider everything in a build.
Already zf-5 swapped
Old Dec 27, 2025 | 09:19 AM
fishfreak101
Originally Posted by 1Butcher
That's what I thought, but I was hoping someone else would point out that.
I was under the same impression just going off the word of the seller who is likely unfamililar
Old Dec 27, 2025 | 09:23 AM
fishfreak101
i don't know. I would not start this swap with a budget that low. Can it be done? Maybe, but what happens when you do have an issue? Front cover/coolant pump seized? Wouldn't you want to reseal the engine? Thermostat? Injectors?
Good luck, but I would take a good look at this mine field before I take the first step.
I'm aware I'll likely end up overspending,really just want advice for parts with everyones understanding it is a low budget build. And of course all of that will be gone through, how could I swap a cam in and not reseal the engine...
Old Dec 27, 2025 | 09:51 AM
rwfid's Avatar
rwfid
I went from driving 351W F150s with E4ODs and 3.55 gears in them to driving a 351W F250 with the ZF5 and 4.10 gears. You might find yourself content with swapping out gearing until you decide that you want to put several thousand dollars into a new engine build.
Old Dec 27, 2025 | 09:55 AM
1Butcher's Avatar
1Butcher
I too went from a 3.55 to a 4.10. I tow a lot and I dislike the slightly higher RPM, but my truck does maintain a higher speed up passes. I would love to get a 6R80.
Do yourself a favor and look at all the threads about the seized coolant pump/front cover bolts. There are plenty out there. Highly unlikely that you will be the only one without an issue AND on a budget. Usually when I am on a budget, everything fails and every step forward includes two steps back. On benefit is that the engine would be out.
Old Dec 27, 2025 | 10:40 AM
Hit Man X's Avatar
Hit Man X
H.O. cam great for budget, we run one in my pal's 351W swapped '89. Maybe can regrind it for bit more ***?
Also has basic bolt on junk like my 302. Underdrive pulley set, 1.7:1 Cranes, long tubes, 2500 stall, Efans, and hmmm about it!
Scoots good even with the pegleg 3.55:1
Old Dec 27, 2025 | 11:59 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Hit Man X
H.O. cam great for budget…
I’m sure I have seen it in one of the many threads but how does that compare to the stock 351 roller cam?
Old Dec 27, 2025 | 12:55 PM
Hit Man X's Avatar
Hit Man X
H.O. are .444 lift, around 115.5LSA. I believe 206/206 duration
351W roller is around .400 lift, about 197/204? Unsure LSA. WAY better than the flat tappet crap cams. I think 302 roller used the same, probably wrong, yet both received a far better unit when went roller.
Apparently 87/88 speed density H.O. cams were a hair spicier. '88 in my 302 as had available on the shelf.
Melling lists specs for stock replacements if you want to look them up
Old Dec 27, 2025 | 02:02 PM
My4Fordtrucks
Search function worked again….
sorry about the size. New phone update.
Old Dec 27, 2025 | 03:32 PM
Hit Man X's Avatar
Hit Man X
Good enough guess for government work!
Note, these are all mass production. So some will rock a Cam Doctor different. Tooling wears, just like your hunting rifle...always neck resize.
Regardless, it is a good cheapo camshaft. NOT great, NOT the best. Sure beats the massive cash they run now, I am floored at their costs
Old Dec 27, 2025 | 04:49 PM
My4Fordtrucks
I have read and saw tests on Engine Masters that split duration cams are better so I’d use the F4TE cam with 1.72 roller rockers.
Old Dec 31, 2025 | 02:42 PM
fishfreak101
Roller block with non roller Cam?
So I picked up the engine a couple days ago, casting number was f4te-6615-aa. But popped the lower plenum off and there are no keepers in the valley, could I have a roller block with a flat tappet cam?
Old Dec 31, 2025 | 02:47 PM
  #28
90project5.0's Avatar
90project5.0
Are the lifters roller? F4 is a roller motor.
I doubt someone put link lifters, but it’s possible.
Old Dec 31, 2025 | 02:55 PM
  #29
rwfid's Avatar
rwfid
Take pictures of the lifter valley, that should tell the tale.
  #30
rla2005's Avatar
rla2005
Both of my 1993 Lightnings had F4TE blocks with flat tappet cams. Very possible for regular production 1993 trucks to have the same, IMHO.
