Wiring headache
Old Dec 29, 2025 | 04:24 PM
Dailydriver22's Avatar
Dailydriver22
I do appreciate all the input, I put a 250 amp circuit breaker in and the glow plug circuit works perfectly now. I did replace the controller already but I am going to go back to the old controller since I know that was not the point of failure.
I do need to make a secure mount for the controller but with a turbo being installed now my controller is up front right behind my ac compressor.
My theory as to the wire melting was that I had an old 35 amp fast charger hooked up to the main battery while I was cranking a lot. I had to prime the IP and set timing so I assumed the repeated cycling of the plugs killed the 40 yr old wires
Old Dec 29, 2025 | 06:17 PM
BigBlue2's Avatar
BigBlue2
Originally Posted by irhunter
The slow-blow feature of links is a commonly-held belief.
"Cheaper" is 100% for sure.
In an earlier post, I asked if modern trucks still use links. It is clear that they do.
To the OP: (1) if both your links blew, I suspect a short-to-ground in the controller, (2) I would troubleshoot the issue and eventually go back to the original two lines going into the controller. Each with either a link or fuse.
If it is the controller, now might be the time to relocate it to a cooler, less vibration, location.
Roy
I didn't know that fusible links were subject to beliefs. I'm guessing were talking here about a 7.3 controller and glow plug circuit. Different from what I have on my 6.9.
So long as all the wiring and components downstream from the 250 amp breaker are robust enough will probably work. I'm hoping the OP has checked it.
Old Dec 29, 2025 | 06:56 PM
Dailydriver22
I have checked it, there is 0 resistance on the circuit and the plugs worked perfectly for a cold start. Just one cycle and she fired up. Did a couple starts today and drove her for the first time in a while. My timing might be a little off since she seems to be lacking hp and making a good bit of white smoke. There is also an exhaust leak but these are issues for another time.
For now all is well and this wiring headache is solved. I appreciate the input from everybody.
In my opinion fusible links are a terrible way to protect a circuit. If a certain part is designed to fail it should be easily accessible for diag and replacing. Maybe one day all of those links will be circuit breakers
Old Dec 30, 2025 | 05:36 PM
BigBlue2's Avatar
BigBlue2
The fusible links aren't designed to fail. When they do fail it's because there's a short or other fault then they do their job same as the fuses in your fuse panel. Do you have breakers on every circuit yet?
oldfatandtired
Nov 12, 2023 03:08 PM
goodB0Y
Electrical Systems/Wiring
13
Jan 29, 2019 10:54 PM
brutus67
Sep 1, 2014 01:14 AM
pizalm
May 7, 2004 07:01 PM
