DEF Fill Issue
Old Dec 18, 2025 | 07:52 PM
barthel's Avatar
barthel
DEF Fill Issue
Greetings all,
Had an interesting thing happen tonight and need some help. I got the "100 miles to go " warning yesterday. I picked up 2, 2 1/2 gallon boxes of Blue DEF, knowing that since it was THAT low, it would likely take both. Well, I uncorked the first box and started to fill the tank, it got to about 2 gallons and then started puking back out through the tank fill. I stopped, let it settle down and started to fill it again, it immediately started backing up again.
Not sure WTF is going on, but I know for a fact that 2 gallons will not fill that tank, anyone else come across this?
Thanks in advance,
Old Dec 18, 2025 | 08:56 PM
SMOKEPLOE's Avatar
SMOKEPLOE
How many miles since you fill the tank? If not towing you should get about 5000 miles give or take on a tank full of DEF.
Smokeploe
Old Dec 19, 2025 | 02:01 AM
Euroman's Avatar
Euroman
If the warning is gone I would be tempted to put some DEF cleaner in and run until the next warning, then see how far you’ve driven, as already mentioned.
Old Dec 19, 2025 | 08:56 AM
Overkill2's Avatar
Overkill2
Originally Posted by barthel
Greetings all,
Thanks in advance,
That is a weird issue to be sure. Did you happen to look in the driver's side wheel well to look at the DEF fill hose?
I replaced my DEF pump and sending unit this fall in my driveway. Its a doable jobnon the ground but a PITA... There's a sleeve in there that goes inside the tank first before the sending unit gets placed inside the tank. I wonder if there's an issue in there for some unknown reason...
Standby for pics.
These are after I pressure washed the top of the DEF tank... and I was installing the new sleeve and sending unit/heater.
You can see the bend in the fill hose from it hanging over. I would check to make sure your hose is not twisted up for some reason. Also do you use a factory fill hose that has a vent hose in it?
New sleeve and sending unit going in.
New sleeve in
New sleeve in
Sending unit in with sleeve, top of sending unit shown there before being placed in the sleeve in tank.
Installing tank back in.   Note the fill hose. Check for that.  Have you done any work to it lately?
Old Dec 19, 2025 | 06:05 PM
barthel's Avatar
barthel
Thanks for the input all, much appreciated.
I can generally get about 6500 miles out of a full tank, but I tow occasionally and drive fast. I only had a half a tank this last time and got 3300 miles out of it.
I did notice some crystallization around the fill pipe, that may be an issue. They replaced my tank heater about 2 years ago, I'd like to think they may have cleaned the tank when they did, but I could be wrong.
Gonna try the cleaner route first, if that doesn't work I may have to go Overkill's route.
Will update when I know something, thanks again!
Old Dec 19, 2025 | 06:07 PM
barthel's Avatar
barthel
Overkill,
As a matter of fact I just had the engine replaced a few months back. That didn't even occur to me.
Old Dec 20, 2025 | 09:08 AM
Overkill2's Avatar
Overkill2
Overkill,
Interesting... keep us posted.
Old Dec 24, 2025 | 03:39 PM
wcbcruzer's Avatar
wcbcruzer
Yours sounds different, maybe a crystallization issue, but I've noticed the factory DEF gauge is somewhat inconsistent. I've had mine puke out DEF twice now after I try adding a whole jug. Super annoying. I usually refill it when it drops to the 60-65% range. Seems like 63% can mean different things on different days cause one time it'll take the whole jug and another time it'll spill out.
Old Dec 26, 2025 | 01:10 PM
Overkill2's Avatar
Overkill2
My buddy just had a 2016 6.7 in the shop where the DEF tank read okay on the gauges but it was at the 500 mile warning. They contacted me via text because they knew I did the DEF pump/sending unit job this year. Plus they asked about the harness behind the fuel tank where mine was opened and one of the fuel sending unit wires was shorting on the fuel tank.
They dropped the fuel tank to inspect the harness and found nothing wrong. They dropped the DEF tank to check the wiring and connectors -- all good. That particular truck was sprayed with anti-rust stuff, do not know what, but my buddy said they cleaned the tank vent fitting because I'd assume it had dirt collected on it from the spray job, they re-installed the tank and it took 5 gallons because the tank was empty when they dropped it. All good now...
As to the OP, I wonder if this possibly could be a venting issue or if there is crystallization in the DEF fill hose or the fitting there.
My buddy stated for his 19 GMC K2500 6.6 Duramax, he used the Rislone additive and said the crystals he had at the DEF fill port just melted away when he put it in his DEF tank. FYI.
PwerStroke99
Nov 5, 2016 09:31 AM
bulla
Oct 28, 2011 09:34 PM
KC8QVO
6.7L Power Stroke Diesel
17
Oct 6, 2011 09:19 AM
dredmond
Mar 29, 2009 08:24 PM
