Clutch Slave
Old Dec 17, 2025 | 02:39 PM
Steve's Avatar
Steve
Clutch Slave
I'm thinking to convert my '56 F100 to the hanging pedals from the '57 through 60 F100. The '56 uses a mechanical clutch, so I'll need to add a master and slave. What I'd love to see would be a photo showing how the slave mounts to a Y-Block.
I'll be putting a new dual reservoir/boosted brake master too as part of a disk brake upgrade. I'd use the '56 kit for the axle, but would use the master compatible with the '57 up.
Old Dec 18, 2025 | 01:03 PM
Byrd.Dog's Avatar
Byrd.Dog
On my 60, the slave cylinder bolted up to the bellhousing, then connected to the fork with an adjustable rod(my trans was a T-98). If you are running the 57-60 pedals in the stock configuration, I suspect the brake and clutch masters will be too close together to run a vacuum booster.
Old Dec 18, 2025 | 01:05 PM
Steve's Avatar
Steve
Thanks.
Turns out my early bellhousing does not have tyhe slave mounting boss, so I'm gonna leave it as is for now.
Old Dec 19, 2025 | 08:49 AM
Byrd.Dog's Avatar
Byrd.Dog
You might look into later-model hydraulic clutch components. I know the ZF 5 & 6 speeds were hydraulic, as well as NV3500's, 4500's, and SM465's in the OBS GM trucks. I actually have a ZF5 that I'll one day swap for the C6 in mine once I get the brakes updated...
Wayzalot
Jul 26, 2023 07:21 AM
Claybreaker144
Jan 25, 2017 09:31 PM
newguy399
Oct 5, 2015 11:28 AM
cheddar89
Feb 6, 2012 09:04 AM
