Hydrolic clutch conversion
Old Feb 5, 2012 | 07:45 AM
cheddar89's Avatar
cheddar89
I got a 63 f100 and was wondering if they make conversion kits to change over to hydrolic clutch or if theres an easy way to convert it yourself id love to have a 5 spd instead of stuffin a c4 in it thanks
Old Feb 5, 2012 | 10:55 AM
Shorty 66's Avatar
Shorty 66
Some of the T5 trannys out of mustangs were cable operated for the clutch release instead of a hydrolic setup.
Old Feb 5, 2012 | 11:19 AM
burdenfabrication's Avatar
burdenfabrication
I don't know if this could be done or not, I do not know of any kits out there to do it. I do know it would require cutting a hole in your firewall for mounting the master cylinder, as well as modifying your clutch pedal for the master cylinder rod to attach to. I also know that Ford used a factory hydraulic clutch system from I think 1957-1960 (I know that my 59 4x4 was equipped with it). You might be able to use a master cylinder for one of these trucks and fabricate a line to go from it to the slave cylinder on your tranny. Good luck and let us know how it turns out.
Bryce
Old Feb 5, 2012 | 02:53 PM
DPhillips's Avatar
DPhillips
I just finished a T5 conversion with a 302 in my 66. In my opinion, a hydraulic clutch id the way to go. Yes, you have to mount a master cylinder and probably get creative with the brake lines out of the brake master, since they want to occupy the same space. I used a Wilwood master and a push type slave cylinder on a bracket mounted to the trans. There are sources for kits with everything included. You'll need to shorten your driveshaft about 1 inch since the T5 is that much longer. Make sure you get the T5 specific bell housing. An original clutch pedal asesembly will work fine. Mine went together with no issues. The truck is much more fun to drive now.
Old Feb 5, 2012 | 10:06 PM
garbz2's Avatar
garbz2
All old type instep cabs have a stamping for a hydraulic clutch.
Here is my 63 ready for a master.
I placed a new clutch arm and used a stock brake push-rod and eccentric bolt.
Garbz
Old Feb 6, 2012 | 09:04 AM
cheddar89's Avatar
cheddar89
I noticed it had a stamping right around that area I didnt know if it would work or not ill have to check that out and try it now time to find a 5spd
Claybreaker144
Jan 25, 2017 09:31 PM
THE71BEAST
Sep 15, 2016 08:21 AM
maf226
Feb 26, 2013 11:53 AM
bmacky14
Oct 13, 2009 08:01 PM
Katmandu
22
Jul 12, 2004 08:34 AM
