I have been searching forever, does anyone make new reproduction grilles? I have a 54 but admittedly the other years all look much better. Id like the 53 if I could find one. I do see some on eBay but they are pretty rough. Thanks!
The 56 grill requires the 56 air dams, lower gravel pan and parking lights...
all the above and the 56 grill (actually all 4 years ) the center grill support is different. So you need the correct center brace for the grill you end up using
also 56 headlight buckets are different than the 53-55 as arr the trim rings
One persons turd is another persons treasure.
I can say getting my 56 grill rechromed was more expensive than a repo.
Some after market air damns are made to use all 4 53-56 grills. https://www.lmctruck.com/body-compon...eel-body-parts
