Sponsored by: Real Truck
Headlight switch question
Old Dec 11, 2025 | 12:21 PM
Big-1's Avatar
Big-1
Does the alarm that goes off when you leave your lights on, is that controlled by a fuse? I left my headlights on the other day and came back to the truck and noticed the headlights were still on. Is that controlled by a fuse?
Old Dec 12, 2025 | 05:14 AM
Clifford Buhrow's Avatar
Clifford Buhrow
4th Gear
Courtesy circuit?
I had similar problem was the GEM
Old Dec 12, 2025 | 10:32 AM
Don Ridley's Avatar
Don Ridley
Need model year.
Old Dec 12, 2025 | 12:43 PM
Big-1's Avatar
Big-1
2007 PSD King Ranch
Old Dec 12, 2025 | 04:08 PM
Don Ridley's Avatar
Don Ridley
I have looked at the wiring diagram and can't find a circuit specifically for the headlight warning chime. All other warnings like door open and seatbelt go to the instrument cluster. Do any warning chimes in your truck work? I think the cluster sees when the backlights in the cluster are on and this triggers the warning chime.
Maybe someone with your model year can verify the chime comes from the cluster.
Old Dec 14, 2025 | 09:09 AM
HearseDriver's Avatar
HearseDriver
I have a dumb question for you - when you left your headlights on and got out of your truck did you get out on the passenger side of your truck? The reason I ask is I back my car into the driveway so close to my other truck I can't open the door. I found out if I leave through the passenger side door rather than the drivers door with the headlights on the "Lights on Chime" doesn't activate. If I exit from the drivers door my Lights on Chime works.
Old Dec 14, 2025 | 11:06 AM
Big-1's Avatar
Big-1
I'm too fat to get out of the passenger side. I've got the bucket seats and center console. Makes it touch.
1979redf250
May 31, 2014 08:58 AM
manlikesford
Aug 26, 2013 07:20 PM
conoso
Aug 1, 2012 07:49 AM
alexchavel
Dec 4, 2009 08:09 PM
rogue69
Electrical Systems/Wiring
Jun 6, 2003 04:18 PM
