Courtesy lights
Old Dec 9, 2025 | 06:12 PM
resco2's Avatar
resco2
4wd High
Courtesy lights
Hey everyone. I'm looking to install some courtesy lights on my 2023 super duty. I wanted to see if anybody had a quick reference as to which fuse location is best to power this acc. The lights are LED so I would assume they don't draw too much power.
Old Dec 9, 2025 | 07:24 PM
djousma's Avatar
djousma
Where on the truck do you intend on installing them? I ask because where might dictate how.
Old Dec 9, 2025 | 08:11 PM
GP_RZ's Avatar
GP_RZ
Think he means floor lights aka courtesy lights. you tie into dome light at or before fuse box.
Old Dec 9, 2025 | 11:39 PM
resco2's Avatar
resco2
4wd High
I'm looking to install running board lights, on the underside of the cab just above the running board. I'm also considering an underhood light.
Old Dec 9, 2025 | 11:41 PM
resco2's Avatar
resco2
4wd High
I would.like to avoid cutting into any factory wiring if possible.
Old Dec 10, 2025 | 05:45 PM
GP_RZ's Avatar
GP_RZ
Why not go off a fuse?
Old Dec 10, 2025 | 10:30 PM
resco2's Avatar
resco2
4wd High
[QUOTE=GP_RZ;21718808]Why not go off a fuse?[/QUOTE
Someone recommended i use a piggy back fuse adapter and tap into a fuse that currently activates the factory courtesy lights,. Are piggy back adapters a good idea? And what fuse controls the courtesy lights? The fuse box cover only has fuse location numbers, no description of what the fuse powers?
bhbdvm
Oct 23, 2019 09:02 PM
dbybee53
6.7L Power Stroke Diesel
May 21, 2018 09:09 PM
Force21
Aug 11, 2013 09:01 PM
glenb5667
Apr 28, 2010 07:38 PM
njkite51
May 27, 2009 01:11 AM
