Multi contour_Max recline
Old Dec 5, 2025 | 11:29 AM
pkarhoff's Avatar
pkarhoff
Trojan Pig
Multi-contour is massage and max-recline are the lay flat. You can get multi-contour without max-recline, likewise you can get max-recline without multi-contour. On both my 21 and 24 platinum trims, multi-contour came standard. On my 24 I ordered it with max-recline on top of multi-contour.
Old Dec 6, 2025 | 07:39 AM
TestPilot57's Avatar
TestPilot57
My '24 Platinum came with massage by default, and I optioned the max recline. I have used the massage many times, and only tested the max recline to make sure it was there and worked. Probably will never use it, but I figured it was better to have it and not use it than not have it and wish I did.
Old Dec 6, 2025 | 09:25 AM
seijirou's Avatar
seijirou
Originally Posted by DanG.
My MaxRecline also massages (Platinum Plus). I'm not sure if they come as 2 separate order items. I will say this. Unless you're 3 feet tall, the MaxRecline isn't all its cracked up to be. To get the full function, you have to pull the seat to the dash and then recline. Someone my size (6'4" and 275 lbs) doesn't have room to get any more recline than a non- max
I'm also 6'4" and my experience is different. I travel and sleep in my truck several times a year and the max recline has been a game changer. That isn't to say it's comfortable, it isn't, but at least now I can lay down. I only need to move the seat forward about 2 inches from fully back where I normally keep it.
Tom
Feb 11, 2021 10:42 PM
