94 f150 4.9 automatic Stalling
Old Dec 3, 2025 | 09:24 PM
Crishcrish7's Avatar
Crishcrish7
6th Gear
My truck will stall when I shift gears, sometimes from D to R or R to D.
It has stalled on me when I came to a stop sign while holding the brake
today I drove it and it shutoff/stalled while I was driving 4x’s, one when I got the stop sign and the others while driving down Main Street (18 mph)
when this happens the rpm’s go up and dip down to where it stalls.
ive replaced the Idle Air Control, EGR Valve, EGR sensor, Cleaned the throttle Body, replaced the Throttle Position Sensor, Replaced Fuel Filter, also has a new Battery
Old Dec 4, 2025 | 11:09 AM
Hurley?'s Avatar
Hurley?
8th Gear
sounds similar to an issue I was having but with a 5.0, would slow down and get choppy when stopped and had trouble shifting. Replaced a multitude of sensors. Then was at O'Reilly and saw they had a deal for injector cleaner and decided that she was old and wouldn't hurt to run a bottle or two through it. Since Ive put the bottles through it the thing has ran fine
tldr; try injector cleaner
Old Dec 4, 2025 | 01:02 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Why? Did you get Key On Engine Off (KOEO) fault codes for those parts and they tested bad?
How would dirty fuel injectors only run poorly when selecting a different gear?
Old Dec 4, 2025 | 03:59 PM
Crishcrish7
6th Gear
I didn’t have any codes, the truck was already idling rough, so I replaced those parts, the truck was driving a little better, But now it won’t stay running.
it starts up every time but will die in seconds.
if I give it some gas it will stay on but one let go of the pedal the truck drops to idle and then just die
Old Dec 4, 2025 | 06:13 PM
My4Fordtrucks
No codes at all? Not even the system pass code? Have you checked the fuel pressure?
Bowers25
16
May 26, 2016 08:11 AM
Sanford Owner
Mar 22, 2006 12:31 AM
90eddiebauer
1978 - 1996 Big Bronco
Jul 13, 2005 09:54 AM
magnut25
1983 - 2012 Ranger & B-Series
Feb 3, 2005 08:00 PM
red5
1997 - 2003 F150
Aug 26, 2004 03:54 PM
