Front axle relocation
Old Dec 3, 2025 | 05:25 PM
story352's Avatar
story352
Just looking to see what anybody else has done when they want to relocate their front axle to more of the center of the wheel well.
i lifted the X with the PMF relocation brackets and I highly recommend that kit to anyone. 2” front and 2.5” rear. I then added zone 2.5” add-a-pack which puts my front leaves at a total of 7 springs per a pack. I highly recommend using those to retain your comfortable factory ride, those and the PMF Monster adjustable track bar fixed a lot of my ride issues but I still scrub a little during certain articulation angles when my wheels are turned. U don’t want to go any higher since I like the look of having it lifted just enough to clear.
so I rub on the pinch seam on the rear of the front wheel well and I believe moving the axle forward approximately 1” would solve that issue and center the wheel with the opening but if I use just a relocation plate then how do you make the pin line up with the shock mount on the front since it also locates on the spring centering pin? I know PMF can make a new shock mount that has holes that can accommodate relocating the shock mount.
I just want to see what anyone else has done when relocating the axle.
huge3fity
Sep 16, 2019 12:01 AM
phlegm
Aug 4, 2016 05:19 PM
special 55
Jul 28, 2011 10:22 AM
92 f150300six
Offroad & 4x4
16
Dec 2, 2004 02:06 PM
RawPower
Feb 19, 2004 07:02 PM
