Crank no start.
Old Nov 30, 2025 | 08:36 PM
Lilbrian86's Avatar
Lilbrian86
5th Gear
Crank no start.
1977 Ford F250 4x4 with a 400ci. Tried starting truck today. But wont start.
As i noticed there is no spark on crank. But when turning key off it will spark when ignition switch is turned off. I did repleace the igntion switch. To no avail still same problem. So i changed the coil and wires and cap and rotor. Which needed to be done. And still there's no spark.
Is there away to test the pick up in the distrubtor.
and also is there away to test the Ignition Control Module? . Thanks Brian.
Old Nov 30, 2025 | 08:51 PM
mterickson's Avatar
mterickson
Spark when you let off the key leads me to think your magnetic pickup failed inside the dizzy, but it could be the ICM too. Here are some tests you can perform to narrow down the culprit.
Old Nov 30, 2025 | 08:53 PM
Lilbrian86's Avatar
Lilbrian86
5th Gear
Also I do need mention the motor thats spec on vin plate is a 351. Not the 400. So im not exact on what year or what the motor came out of. But will start with those tests. Thanks.
also the pickup is has the blue color and also so does the icm module.
any idea how to tell if its dura spark I or II?
Old Nov 30, 2025 | 08:57 PM
mterickson's Avatar
mterickson
That doesn't make any difference, the ignition components from mid 70s to mid 80s were very similar and use the same tests. You have duraspark II, the duraspark I was only in cars in the early 70s as far as I recall. The pickups switched from points to electronic ignition in '75 and jumped straight to duraspark II. 351M/400/460 all use same dizzy.
Old Dec 1, 2025 | 05:27 PM
Lilbrian86's Avatar
Lilbrian86
5th Gear
So i tested the pickup. Only have continuity to ground on black wire. Ohms resistance between orange and purple is 623.
still only have spark when shut off ignition switch
None while cranking.
also I have 12 volts on the 2 wire plug on the red wire while in run position. Nothing on white. And also have 12 volts on the green wire in 4 wire plug.
Old Dec 1, 2025 | 06:10 PM
JimsRebel's Avatar
JimsRebel
The single spark when shutting off the power is caused by the field collapsing. This also proves that there's current flow though the DS2 ingition module and that it's power ON.
The 12 volts on the green wire must have been measured with the 4 wire plug disconnect.
Is the rotor turning?
Per the manual, you are supposed to be able to hit the distributor, near the pickup, with a screw driver handle. Each whack is supposed to produce a single spark. The HIT is supposed to SHOCK the magnetic pickup, and send the small voltage spike to the DS2 ingition module. If the test works, it proves the ignition module is OK.
Personally this seems a little magical , but it has been done by others.
You can also measure the gap, tooth to magnet. It's not adjustable, but to big of a gap and it won't work. Or if its rubbing , it won't work.
Jim
Old Dec 1, 2025 | 06:14 PM
JimsRebel's Avatar
JimsRebel
https://www.ford-trucks.com/forums/1...uctor-gap.html
Reluctor gap info
Old Dec 1, 2025 | 06:21 PM
JimsRebel's Avatar
JimsRebel
You should do this test at the 4 wire connector on the DS2 ingition module, as this will also test the wiring all the way to the ingition module.
Not sure if you tested at the distributor or ingition module.
You know that the ground is good, because the module is powering ON
Also, do a key ON , coil positive voltage test with everything connected in a RUN configuration. Should be about 6 to 8 volts.
Jim
Old Dec 1, 2025 | 06:37 PM
Lilbrian86's Avatar
Lilbrian86
5th Gear
With all hooked up and ignition on. I have just over 7 volts to the coil.
Old Dec 1, 2025 | 06:51 PM
JimsRebel's Avatar
JimsRebel
That's a good reading.
How did the whack a distributor test go?
Jim
Old Dec 1, 2025 | 06:52 PM
Lilbrian86's Avatar
Lilbrian86
5th Gear
Where's best place to give a little whack. Lol.
Old Dec 1, 2025 | 07:29 PM
JimsRebel's Avatar
JimsRebel
Close to the magnet pickup.
Red117
31
Oct 5, 2025 03:32 PM
MEDEVAC247
26
Feb 29, 2024 04:56 PM
BigDogE80
Feb 15, 2024 08:26 PM
chris1052
Dec 21, 2023 08:47 PM
MitchStanley
34
May 31, 2011 08:26 AM
