Automatic to stick
Old Nov 26, 2025 | 07:37 PM
Nitro1168's Avatar
Nitro1168
Automatic to stick
I’m thinking of buying this 67 f100 with a 390. It has a fmx automatic in it. I really wanted a stick. Has anyone on here made that switch. I really don’t know what transmission I would be looking for. Also would the dent side pedals work?
Old Nov 27, 2025 | 10:43 AM
Green72F250's Avatar
Green72F250
Here is some good information on the brake pedal assembly's: Comparing Clutch/Brake Pedals and Brackets - FORDification.com
Old Nov 27, 2025 | 11:13 AM
Nitro1168's Avatar
Nitro1168
Thank you for that. Not as easy as I thought lol. That was a big help
Old Nov 27, 2025 | 12:11 PM
1browski's Avatar
1browski
Just need a donor truck with manual tranny in it. I couldnt get into Fordi for some reason. Not sure on the 67s but does it have all manual brakes? Power steering? There could possibly be a lot more to swap than just a trans and pedal assembly. Without adapters and extra work, T18 and NP435 will swap straight in.
Old Nov 27, 2025 | 06:11 PM
jzjames's Avatar
jzjames
My comment on this; think long and hard about converting to manual from automatic.
I thought I would like to do this someday also. Then I was at a car show and some old-timers talked me out of it. For these trucks, auto is much nicer.
Stop and go driving these days, and a good automatic will be much appreciated.
Old Nov 27, 2025 | 11:14 PM
BobbyFord's Avatar
BobbyFord
Someone explain the advantage to have a manual granny low 4 speed in a F100 truck.
Old Nov 27, 2025 | 11:27 PM
Wangdangdoodle's Avatar
Wangdangdoodle
I have an NP435 and all accompanying hardware (except clutch pedal) sitting in my garage. My project is switching over to a TKX transmission and hydraulic clutch. I even bought new bushings and stuff for the linkage rebuild before I decided to go hydraulic. Let me know if you're interested.
Old Nov 28, 2025 | 02:17 AM
Nitro1168's Avatar
Nitro1168
Ok I will, let me think it over. Thank you
Old Nov 28, 2025 | 07:27 AM
'65Ford's Avatar
'65Ford
The T18 and NP435 are fine trannies. Though the only benefit over an auto from the same time period I can think of in an F100 is engine braking if you're on a lot of hills.
If you have the time and skill, might consider a Tremec tkx (as already mentioned)...five speed with easier and faster shifting than a T18 or NP435. Another option is the Tremec tr4050 which has gear ratios more suited for a truck if you're towing.
In the auto category, it's worth mentioning the Ford 6r80. There is an adaptor kit available. You'd get a modern 6 speed auto with lock up torque converter...about as nifty as you can get in an F100.
Any tranny swap option only requires time, skill, and a chunk of money...
Old Nov 28, 2025 | 12:19 PM
WDXPW's Avatar
WDXPW
Are gear ratios the only difference between a NP435 and a newer tr4050 ? Are they both bolt in replacements for a NP435 ?
Old Nov 28, 2025 | 05:01 PM
1browski's Avatar
1browski
T18 and NP435 have no overdrive.
Steven@nd
Vehicles for Sale
Aug 27, 2016 11:58 AM
huntinzombie
May 28, 2015 12:16 PM
Smellii
Feb 10, 2013 10:22 AM
tfynes
Sep 8, 2006 12:10 AM
The Yooper
Sep 9, 2005 10:00 PM
