Sponsored by: Real Truck
Spring codes
Old Dec 8, 2003 | 06:33 PM
hang10's Avatar
hang10
Spring codes
What are the spring codes on the door post sticker? What are the decodes and how many different codes are there? I am interested in 03s. I do not have the plow pkg to my knowledge, however, my front end is a little higher than my tail. Thanks..
Old Dec 8, 2003 | 09:41 PM
n578md's Avatar
n578md
Here are some code listed in my manual:
F250/350 2WD
Code Front GAWR (lbs.)
B 3200
C 3350
D 3500
E 3650
F 3800
G 3950
H 4100
I 4250
J 4400
K 4550
L 4700
F250/350 4WD
R 3600
S 4000
T 4400
U 4800
V 5200
F250/350 options and F450/550
W 5600
X 6000
Old Dec 8, 2003 | 10:05 PM
hang10's Avatar
hang10
On my sticker it has 'SP' I don't see a 'P' on your list. S/4000, kind of weak isn't it?
Old Dec 8, 2003 | 10:16 PM
n578md's Avatar
n578md
P is 6830 lbs, sorry the rear are in another section. I had FP, 3800 front/6830 rear. Now I have a V10 front coils (G). Look on your tag at the section on the right side that looks like:
F297
T842
This tells you the reserve weight for accessories. F is FRONT T is TOTAL. I can had 297lbs of "equipment" to the front axle. (winch, push bar water pump etc...) What does yours say?
Old Dec 8, 2003 | 10:23 PM
n578md's Avatar
n578md
4000 seems right for a V10 4x4. That engine isn't very heavy, just 135lbs more than the 5.4L according to this book.
Old Dec 8, 2003 | 10:33 PM
hang10's Avatar
hang10
F297
T842
If I read this right, I can't have much:
F0021
T0842
So I can only have 21 lbs on the front?
Old Dec 8, 2003 | 10:37 PM
n578md's Avatar
n578md
Yes, my 1999 4WD had about the same. A lot of reserve weight is taken up by your extra stuff like transfer case and all that+. So if you were to put a 130lbs winch, in theory, your truck would ride lower. (Probably not by much.) If you stand on the bumper does the truck go down any? My truck doesn't move any but I don't weigh anywhere near 297lbs.
Old Dec 8, 2003 | 10:57 PM
n578md's Avatar
n578md
This is what the manual says about that:
Maximum Allowable Weight (RPO & Aftermarket Equipment)
Less Actual Regular Production Option Content Weight
(from Line A, Payload/GVWR Worksheet)
Equals TOTAL ACCESSORY RESERVE CAPACITY
(The maximum weight that may be added to the Ford completed
vehicle must be less than this figure. This Accessory Reserve
Capacity calculation approximates the figure which will be
computer-printed on the Safety Compliance Certification Label
located on the driver's door latch post)
Not very helpful but I guess those numbers are more for legality than anything else.
Old Dec 8, 2003 | 11:01 PM
hang10's Avatar
hang10
Never stood on the front but I do recall when I first got the truck, that I stood on the rear and it went down a bit, felt kind of like my F150. I weigh about 225+.
So what does that mean in reality? That if I were to install a brush guard type of thing that weighed over 21 lbs, I would be overloading the front axle? Voided warranty and all that? I guess I am having a hard time understanding the meaning. Total = 842. Where? If you can only have 21 on the front, that means 821 rear?
Old Dec 8, 2003 | 11:18 PM
hang10's Avatar
hang10
wonder why then, I am nose high, if I am 21# to max on the front end. I would be overloaded after a snow if all it takes is 21 lbs...
Old Dec 8, 2003 | 11:32 PM
n578md's Avatar
n578md
from what I understand of this paragraph, if you took your truck and filled it with all fluids and 3380 lbs of payload, 3 passengers, and 21 lbs of extra equipment, your truck would weigh 8800lbs and still be within the "legal" limit set on your sticker. (8800 lbs for F250 reg cab 4x2.)Now if you wanted to add a ranch-hand bumper that weighs 310 lbs or about 280 lbs more than the stock bumper, to reach the 8800 lbs certification limit on your truck, you would have to pull 280-21 = 259 lbs out of somewhere to still be legal. For example I would throw my wife out 120lbs + her stupid sister 139lbs and benefit of a 1) a quieter ride and 2) a legally loaded truck albeit at its limit. (or you could reduce your payload from 3380 to 3121 lbs. (I think)
Old Dec 8, 2003 | 11:35 PM
n578md's Avatar
n578md
Snow? What is that?
Old Dec 9, 2003 | 12:06 AM
hang10's Avatar
hang10
Well, I guess I am in luck. My wife weighs 118 and only has a stupid brother. I get it, I think. I was breaking the weights up per axle. So I can go ahead and hook that cow catcher on the front end and be okay, as long as I can steer, stop and not go over the total weight.
Old Dec 9, 2003 | 12:16 AM
n578md's Avatar
n578md
I watched Ranch-Hand install the front-end replacement bumper on my old truck (4WD) and if the suspension went down at all, it probably went down by 1/8" at most so your'e probably pretty safe. I guess the reason why the reserve is so low in the front is that the front axle has to support the weight of the engine, the cab/passengers and running gear and maybe 1/4 of the payload in the bed. That's a lot of stuff. Your Dana 60 can do about 5200 lbs max. while the Ford 10.5 in the back can do 6830 lbs.
Old Dec 9, 2003 | 12:21 AM
hang10's Avatar
hang10
Still wondering why I am nose high now, with an empty bed. I would think I would be slightly tail high.
