Is your truck lifted or stock? When I got my 2WD lifted it looked nose-high as well. When a friend and I measured it (top of wheel arch to ground) , it was exactly level. My friend says it "looks" like it is nose-high because the hood line is higher than the bed. So to correct the optical illusion, I had the lift kit installer swap the 1" rear blocks that came with the kit with 3" blocks.
Originally posted by n578md Is your truck lifted or stock? When I got my 2WD lifted it looked nose-high as well. When a friend and I measured it (top of wheel arch to ground) , it was exactly level. My friend says it "looks" like it is nose-high because the hood line is higher than the bed. So to correct the optical illusion, I had the lift kit installer swap the 1" rear blocks that came with the kit with 3" blocks.
Stock. I will live with it. Doesn't bother me enough to spend money on correcting it.
