Timing
Old Nov 22, 2025 | 09:56 AM
fire.ice07's Avatar
fire.ice07
Timing
I don’t need to time my truck but it would be good to know if I ever need to…..Just wanting to know how to properly time my 1949 f1 with a flat 6 (226) converted to 12v. I read something about a sight glass on the bell housing which I haven’t found. Any input on all there is to know about timing.
Old Nov 22, 2025 | 10:06 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
It is all in the shop manual - you should get one if you don't have one. It outlines using the timing marks on the front cover in conjunction with markings on the damper.
Old Nov 22, 2025 | 10:47 AM
ALBUQ F-1's Avatar
ALBUQ F-1
There is very little to it.
Old Nov 22, 2025 | 10:56 AM
bmoran4's Avatar
bmoran4
That excerpt is from the engine tune up section. Go back to Chapter 4, Part One, Section 1 on the ignition system... It shows the various timing mark styles, which one to use with which setups, how to determine TDC and so on...
Old Nov 22, 2025 | 12:23 PM
mtflat's Avatar
mtflat
There is no "sight glass" on the bell housing.
There is a clutch inspection cover that can be accessed under the transmission hump in the cab, but it has nothing to do with timing.
Kev1180
Large Truck
Sep 2, 2015 03:56 PM
coletrain777
22
Mar 18, 2011 08:06 PM
tardster
16
Aug 10, 2010 11:45 PM
Green Streak
Mar 7, 2007 08:35 AM
j tate
Nov 30, 2006 06:18 PM
