I'm preparing to install my gear vendors in my 76 2wd sc behind the c6.
I'm trying to decide what exactly to do about the driveshaft. I have a 2 piece shaft presently but am unsure what I will be doing. I was hoping someone else has done with this.
I am going to measure things and see if a one piece shaft might be a good plan
I installed a GV in my highboy with an NP435 so it's somewhat different. it would probably be easier to shorten your front shaft, but you could probably just go to a single longer one.
Are you going to go with the full auto set up or use the manual switch on the GV?
You'll like it. I didn't do it so much for the extra gears I wanted the OD. and it's so much nicer.
I'm pretty stoked to get the drivetrain back in. I called gearvendors and their advice didn't seem right.
I'm not sure why you have a two piece drive shaft in a two wheel drive. Is it a long bed? You should have to shorten the drive shaft as the GV is a little longer than the tail shaft.
Sc long bed. It is all stock. I'm going to call the driveshaft guy today and see what he says
I don't recall how long your front driveshaft is, but I would think you could shorten it easier and cheaper than building a new one and eliminating the carrier bearing. you're looking at about 2' for the GV, so if your front shaft is 5' or so I'd shorten it, if it's less than that a new shaft might be a better idea.
my shaft between the transmission and transfer case was already short, but Tom Woods came up with an idea that works great. if you're not sure about who you're using call him they're the best.
The front shaft is honestly pretty short. I'd estimate maybe 3' or less. I'm going to roll the truck in and jack it up for better measurements. I have a fixed gv yoke and the front shaft doesn't have a slip in it. Gv said to leave that. My original arrangement had a slip yoke at the c6 rear ..I'm conflicted about that recommendation
The GV will add about 2', so if your front shaft is 3' a 1' driveshaft is doable. but I would think a one piece that's 1' longer than a standard cab would be cleaner and no problem at all. if you're not sure you could talk to woods and get a professional opinion .
In my 79 F350 I had to have the driveshaft shortened 4 inches when I switched from the C6 to an E4OD. Mine is the 2 piece style and I had it shortened at a place called PEM in St Clair MO. It wasn't very expensive to have done and they rebalanced the whole thing as a unit.
With the longer transmission I had to shim the carrier bearing a little bit lower to make everything complementary in the drivetrain. I'm thinking that I had to drop it down about 1/4 inch but it has been a while since I looked at it.
I don't doubt I will be moving the cb due to the change.
I got under the truck today and I was wrong. The front shaft is prob 5 ' long. I'll have that shortened for sure and check ujoint angles and equalize them.
Take the front and rear in so it can be balanced as a unit.
Just taking in the front by itself would be like taking just the rim of a two piece wheel in; when it all bolts back up, odds are good it won’t be balanced.
Yes, I'll actually have him do a new carrier hearing and quality u-jounts. I just sure would think a slip yoke at the rear of the gv since the carrier hearing is fixed would make sense. Unless the engine ,trans,carrier would never move...
I'm not saying it can't be done, I said it's not done. good luck finding a local shop who doesn't zero balance everything independently. there's nobody in my half the state who could. just balance your new shaft and if it's not smooth zero balance the other.
I watched Kenworth balance driveshafts and they're done one at a time.
