DRL brightness issue
Old Nov 18, 2025 | 12:26 PM
expy03's Avatar
expy03
Wondering if anyone else has had an issue with their LED "C/Bracket" DRL lights not functioning correctly?
The Driver's side light is fine and bright. The passenger side is noticeably dimmer than the driver's side. However, it is of equal brightness when the truck is in drive. It also disappears when I use the right turn signal. The driver's side does not disappear when the turn signal is engaged. There was a recall a few years ago where the NTSB made Ford reduce the brightness of these lights. Any thoughts as to the cause would be appreciated. Control Module issue? Headlight issue? FORScan issue?
thanks,
Maksimpson
Apr 30, 2024 03:37 PM
donmi
Feb 18, 2015 10:32 PM
jnggatts
Jun 12, 2011 08:47 PM
jnggatts
Jun 12, 2011 08:43 PM
sethro
Electrical Systems/Wiring
Jan 25, 2005 06:44 PM
