Sponsored by: Real Truck
Question about abs light
Old Dec 18, 2002 | 05:04 PM
stokbridge's Avatar
stokbridge
I just replaced the abs unit for the rear brakes in my 1995 f-350 7.3 psd. I hastily removed the old rusty unit, and forgot to note which lines went to which ports on the unit. Anyways, I reinstalled it today, and all seems to be working right except the abs light won't turn off. Could I have reversed the brake lines? I blead the abs unit and all the brakes, but the light stays on. Any ideas? I connected the port towards the front of the truck to the master cylinder. Any help would be greatly appreciated, Tim.
Old Dec 18, 2002 | 11:18 PM
wolfmanagh's Avatar
wolfmanagh
Is there enough play in the lines to put them in the incorrect spots?
I would guess you have them in the right spots myself. Unless your unsure. If I was unsure I would look around for another truck to compare with.
Old Dec 21, 2002 | 01:16 PM
babarche's Avatar
babarche
Here is a picture for reference:
https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=11376&width=0
What was the reason you replaced the part, was it just because it was too rusted? Also, was it a new or used part that you installed? The light generally indicates an electrical fault, did you do anything else related to electrical system? The brake lights can cause the light to stay on, if they are not connected, or if they are replaced with LED lights.
There is a connector under the passenger side of the dash that connects a single red wire to a single black/orange wire. With the ignition in the on (run) position, disconnect this connector and connect the black/orange wire to ground (vehicle body sheetmetal)using a jumper wire. The ABS light will blink out a code, similar to a check engine lamp flash code. Count the flashes, two digit codes will be flashed by a group of flashes, a pause, then another group of flashes.
Let us know what codes you get, maybe we can determine what is causing the light to stay on based upon the codes that are stored.
Brian
Old Dec 21, 2002 | 02:46 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
rjarizona
15
Oct 18, 2022 08:38 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Dec 18, 2014 07:33 AM
liberty2701
13
Aug 12, 2011 07:33 AM
Night Rod
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 29, 2011 03:56 PM
poorboy292001
Aug 24, 2003 10:51 AM
