Tranny Fluid
Old Nov 14, 2025 | 07:46 AM
My93F250NH's Avatar
My93F250NH
Tranny Fluid
1995 F250HD, ZF5, 460, 113k miles
My transmission shifts and drives, but you feel it "touch" the gears on most shifts. Not a complete grind, but you know that two gears have come together.
I don't know what fluid is in the transmission, so I'd like to change that out in an effort to perhaps make the shifts a bit better. I suspect the synchros are near end of life, maybe I can squeeze out a little bit more life. I only plan to put 1k to 2k mi per year on the truck.
Any recommendations for transmission fluid for an older ZF5? Something to help the synchros do their job a bit better? I know Mercon is the requirement, just wondering if anyone has had good luck with a particular brand, or synthetic, for this specific use case (older tranny, prob needs synchros).
Old Nov 14, 2025 | 12:02 PM
knottyrope's Avatar
knottyrope
Mercon V Synthetic is what i use in mine
Can you shift into first easy? If not the clutch might need to be bled. I take off the slave and compress it ten times fully. Also drain the fluid by dipping in a rag and adding in some fresh fluid helped a lot.
Old Nov 14, 2025 | 01:06 PM
My93F250NH's Avatar
My93F250NH
Yah, first seems to be okay. Most noticeable problem is third. Doing a bunch of research this morning, I ordered Redline MTL. I'll update the thread and let you know if it made any difference.
Old Nov 15, 2025 | 09:44 AM
1Butcher's Avatar
1Butcher
I use GM Synchromesh, sure, it's for a VW transmission, but it helped my shifts.
If the clutch is dragging, that could cause your issues too.
Old Nov 15, 2025 | 09:51 AM
My93F250NH's Avatar
My93F250NH
Clutch is new (along with throw out bearing, flywheel etc.). But who knows. It's entirely drivable, just like to hunt down potential issues. I'll report back later today (hopefully) on the Redline.
Old Nov 15, 2025 | 10:38 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I agree. Since this:
seems to be all the gear changes with 3rd being the worst. That is usually a clutch issue.
That doesn’t mean anything if the hydraulic system isn’t fully releasing the cutch disk when shifting. Do you have a good, firm pedal? Is the firewall flexing when the pedal is pressed? Are the bushing on the pedal assembly still there and not broken or missing?
Old Nov 15, 2025 | 11:14 AM
My93F250NH's Avatar
My93F250NH
Thanks for the insight. I replaced the clutch pedal shaft bushing. I know it's temporary, but ok for now. I didn't see any ovaling of the hole. The old bushing was there, but near the end. Pedal feels very firm. I haven't checked for firewall flex but will. I'll get the fluid changed and let you know where I am.
Thanks again for the help.
Old Nov 15, 2025 | 02:46 PM
My93F250NH's Avatar
My93F250NH
Drained and replaced with Redline MTL. Shifts are improved. Not perfect, but good. I've never driven a ZF5 before - some of this might be my getting used to this tranny.
For the moment, I'll consider this solved. Thanks again.
murrhee
Jun 18, 2009 09:24 PM
SnowHiker
1997 - 2003 F150
Dec 15, 2007 06:56 PM
RobertJohn
Dec 15, 2007 01:06 PM
xtmsports
15
Aug 19, 2007 05:19 PM
Dre82s
Feb 15, 2007 08:27 PM
