knock sensor, O2 sensor, computer
Old Nov 16, 2025 | 10:29 AM
BigBeast's Avatar
BigBeast
That's a great shot of it, Max, and thanks again for going to all that trouble. There definitely is a port cast into the body in that location, but it doesn't go right through and it's not threaded. I guess our engineers over here decided not to bother with that particular EEC input?
Old Nov 16, 2025 | 10:39 AM
BigBeast's Avatar
BigBeast
Those links don't seem to work for me, Max...I just end up back here again. Probably something connected with my firewall, maybe. That's cool though...I'll just wire the sensor back into its circuit and leave it lying there where it always was.
Old Nov 16, 2025 | 10:48 AM
BigBeast's Avatar
BigBeast
I've never had good economy, Dave: four kilometers to the litre at best. I figure fitting bigger tires gets you an overdrive...but then there's the increased rolling resistance of the larger tire, of course. Maybe you're right. I'll check it out if I can.
Old Nov 16, 2025 | 12:03 PM
Franklin2's Avatar
Franklin2
I do not know about not being threaded, but the sensor location will not go through anywhere. It just mounts in the engine and listens for spark knock.
Old Nov 16, 2025 | 12:05 PM
Max Capacity's Avatar
Max Capacity
BigBeast, if you type in www.garysgaragemahal.com then look down for my post 1986 F350 302EFI knock Sensor....
Like Dave said, its not going to be a through hole.
Old Nov 16, 2025 | 04:35 PM
BigBeast's Avatar
BigBeast
I did manage this time to get through to the new forum, Max, and all the comments there are helpful all right, but I can't yet figure out how to post there. It seems I once started an account there, but can't remember the password, and as my email address has changed since, the "reset password" isn't working. Sorry to be a pain...I'll sort it out as soon as I can.
Old Nov 16, 2025 | 05:32 PM
Max Capacity
I would think you could reach out to Gray Lewis as that's his site and he's in that thread, I'm sure he would help you. That site had lots of great info up top on the tool bar.
Old Nov 16, 2025 | 08:47 PM
FuzzFace2's Avatar
FuzzFace2
I think you can email Gary or the Admins to let them know what is going on with your account & email address change.
Dave ----
Old Nov 19, 2025 | 11:05 AM
BigBeast's Avatar
BigBeast
Hi, fellas. Tried the email thing, but I suspect it never got through to Gary, as the system asked for verification via my email, but nothing appeared there, even though I'm on their world map of members (Kevin Elvey). Ah well. I'm not fussed.
I get all the help I need from you fellows, and thanks very much for that.
Old Nov 19, 2025 | 03:11 PM
FuzzFace2's Avatar
FuzzFace2
At the bottom of the main page there is "contact us" and it brings up a text box.
I did not try and fill in anything but I dont see why it will not work if you send them your used name and new email address for a password rest.
Good luck
Dave ----
Old Nov 20, 2025 | 03:04 PM
BMWZ4Mguy's Avatar
BMWZ4Mguy
My 86 Ford 5.0 EFI OD manual transmission truck did not have a knock sensor in it when I got it, and replacements that fit are not available (just learned that the ‘87 knock sensor can be adapted with a thread adapter apparently, something to consider). Seems to run ok without it, at least I don’t hear any pinging.
Old Nov 20, 2025 | 03:07 PM
Max Capacity
I'm wondering it the thread adapter moves the sensor out, further away and the knock is somehow changed...if that's somehow an issue... I'm also trying to learn, just in case.
If yours runs fine without... I wouldn't fix what isn't broke... ?
Old Nov 21, 2025 | 07:06 PM
  #28
BigBeast's Avatar
BigBeast
Tried it, Dave. Same story: promises to send a link for verification to my email box...and zilch. I'm done. Thanks anyway, mate.
Old Nov 21, 2025 | 07:11 PM
  #29
BigBeast's Avatar
BigBeast
Interesting. I had a mechanic give the old girl a tune up about twelve years ago and he said it was the smoothest running V8 he'd ever worked on.
e1p1
Mar 7, 2008 05:08 PM
Jeff_G
1983 - 2012 Ranger & B-Series
Aug 12, 2006 05:47 AM
77bigblock
Jan 22, 2006 01:07 PM
Jharger
Apr 23, 2005 12:39 PM
Jrock909
Dec 22, 2004 11:43 AM
