Interchage ability
Old Nov 12, 2025 | 06:25 PM
RevvinRich's Avatar
RevvinRich
1st Gear
Interchage ability
I have a 92 F150, Transfer case needs replacement. I have the running ear from a 84 ( approx. ) can the Transfer case from the 84
Fit into my 92 F150 ?
Old Nov 12, 2025 | 07:05 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
From what DaveF has posted I believe the answer is yes it should bolt to the transmission but .............
1- Would be how the 2 get shifted from 4x2 to 4x4 to low range.
2- The other would be driveshafts and how they bolt to the transfer cases.
I cant think of anything else but if I am wrong I am sure someone will say something.
Dave ----
Old Nov 13, 2025 | 05:23 PM
Franklin2's Avatar
Franklin2
If you have the shifter for the 1984, you should be able to make it work, may take some floor modifications. And like was mentioned, the output of the 84 may be the same or may be different. If it's different and both trucks were the same wheel base, you may be able to use the 1984 rear driveshaft. You can definitely make it work, you just need the right parts to do it.
1979 300i6
WTB - Parts & other
Apr 26, 2017 09:17 PM
dankeith87
Oct 9, 2007 07:41 PM
rick90yj
Nov 17, 2004 07:27 PM
