Charging issues after replacing starter??
Old Nov 11, 2025 | 06:58 PM
RUSTEZE's Avatar
RUSTEZE
I recently had to replace my starter on my 7.3idi, and I went to a gear reduction one from oreilly’s (P/N R812323). With the excess cranking from the poor starter beforehand, it fried my alternator. Replaced it and jumped it, still wasn’t charging. Checked regulator by unplugging and jumping F and A terminals in the plug, and it still isn’t charging.
what should I check next? Both the alternator and regulator are new. Could it just be a poor connection from the alternator to the batteries? Or could it be something different?
Also, I replaced the starter solenoid right behind the battery at the same time I was replacing the starter. Could I have simply misplaced a wire to the wrong stud when installing the new one?
I will add a photo of the new solenoid with wires hooked up later this evening so yall can see if any are hooked up wrong.
EDIT:
Figured it out. I had the fusible link wire going to the battery lug on the alternator on the wrong side. Guess I should pay more attention to wire locations in the future when I take stuff off lol
Old Nov 12, 2025 | 06:29 AM
tjc transport's Avatar
tjc transport
i ain't rite
mehh. dont beat yourself up too hard, it is an easy mistake to make. none of us are perfect askwholes, no matter what our wives may say
Old Nov 12, 2025 | 08:19 AM
WCMtn1990's Avatar
WCMtn1990
EDIT:
Anymore when it comes to wiring I ALWAYS take a picture before disconnecting a bunch of wires because there will always be that one wire that you can't quite be sure where it went.
Old Nov 12, 2025 | 09:28 AM
tecgod13's Avatar
tecgod13
That's one of the best features of a smart phone! Can take a picture, even in the dark, and instantly be able to reference it. Great for wiring, brakes, basically anything you have to disassemble. Alot faster and more reliable than trying to draw a picture.
4.2v698.5f150
3.8 & 4.2L V6
Jun 10, 2024 11:19 AM
twom7
May 6, 2013 06:07 PM
Fordzilla80
Sep 1, 2008 04:46 PM
wroper
Jun 8, 2008 06:52 PM
