Adding additional fuel check valve
Old Nov 10, 2025 | 08:27 AM
Stumpalump's Avatar
Stumpalump
2002 E350 V10 139k miles. After it sits for a couple of days it stumbles and runs ruff for about 10 seconds. Throws lean codes. From what I understand and have been told the check valve in the fuel pump that holds pressure in the fuel rail is not holding pressure. The known fix is fuel pump replacement. I’d like to just add an aftermarket check valve somewhere between the tank and fuel filter or somewhere before the fuel rail. Any advice, suggestions, or experience appreciated.
Old Nov 10, 2025 | 12:39 PM
etinpa's Avatar
etinpa
Not familiar with the 2002 but usually the fuel pump runs for a few seconds when the key is turned to the RUN position. Try leaving the key in RUN for a few seconds before turning the key to START. That might give some insight...
Old Nov 10, 2025 | 12:42 PM
tabijan's Avatar
tabijan
Does it run better from cold start if you cycle the key to run a couple of times before starting?
Short of a personal recommendation, ask Summit or Jegs for their advice on a check valve rated for your V10s fuel flow rate. Back in the day, I'd trust components from Earl's, Moroso, Russell, ...
Sixto
07 E350 5.4 200k miles
Old Nov 10, 2025 | 08:42 PM
Stumpalump's Avatar
Stumpalump
That used to help but it got so bad that when I start it stumbles and throws codes.
Old Nov 10, 2025 | 08:43 PM
Stumpalump's Avatar
Stumpalump
Sixto
At first it only did it if it sat for a week. Now it does it after a few hours.
Old Nov 10, 2025 | 10:22 PM
tabijan's Avatar
tabijan
Are you sure it isn't the fuel pump giving up?
Sixto
Old Nov 11, 2025 | 04:23 AM
manicmechanic007's Avatar
manicmechanic007
I'd drive it around with a fuel pressure gauge taped to the windshield
Sounds like a failing fuel pump top me too
Old Nov 11, 2025 | 07:38 AM
econo93's Avatar
econo93
Mine died at 136k. Typical mileage?
Old Nov 12, 2025 | 04:08 AM
manicmechanic007
Yes, I used to tell people to expect fuel pump failure around 110k
The fuel pumps last a little longer these days, now that they run on a duty cycle, and not just run constantly
Your 02 will be a 2 fuel line system, with a pressure tap, the pump on yours runs constantly
corvaidan
Jan 3, 2023 12:57 PM
psychedelicpuffin
Aug 14, 2020 07:39 PM
1993 ford
24
Jun 25, 2017 11:22 PM
jonathan9573
Aug 7, 2014 02:48 PM
kjoy1
Sep 9, 2004 11:52 PM
