Check fuel pressure before the schreader valve
Old 08-07-2014, 10:29 AM
jonathan9573's Avatar
jonathan9573
jonathan9573 is offline
Where and how can i test fuel pressure before the schreader valve? I am trying to track down a fuel pressure problem and want to see if it is the fuel pump, fuel filter or FPR.
Old 08-07-2014, 02:48 PM
subford's Avatar
subford
subford is online now
Replace the fuel filter and then check it at the schreader valve.
Fuel must get to the FPR to set the pressures that you need to check.
Without the FPR the fuel pressure can be 95-100psi.
If you would have said how do I check fuel volume then that would be a different story.
Here is that story, some good ideas:
troy676
1983 - 2012 Ranger & B-Series
12-13-2013 09:50 AM
HD Rider
12-05-2010 10:01 AM
caseydudem
08-03-2010 02:50 PM
sharky
06-19-2006 07:27 PM
01stroker
07-27-2004 08:22 AM
Quick Reply: Check fuel pressure before the schreader valve
