Another.. gear pattern thread!
Old Nov 10, 2025 | 08:12 AM
N147JK's Avatar
N147JK
Any comments on this pattern appreciated.
Axle is a Dana 60 with new Dana ring and pinion + new bearings.
Looks OK to me so far but drive side is up toward the toe.
Coast side looks good.
Backlash is .005 - might be a tad tight.
Should I work on increasing the backlash?
Thank You
Old Nov 10, 2025 | 08:31 AM
HRDROKN's Avatar
HRDROKN
Pinion too deep... .005 is a little tight though, so I would adjust backlash first. If still deep (toe) then take .002 out of pinion depth, then redo backlash and read.
Old Nov 12, 2025 | 11:54 AM
N147JK's Avatar
N147JK
Here's an interesting find. This is a Dana document that describes desired contact patterns. It says the drive side ought to be toward the toe end.. just so long as it doesn't run off the toe end.
Old Nov 12, 2025 | 12:39 PM
HRDROKN's Avatar
HRDROKN
Well, that is an interesting find... so, with that just adjust your backlash and read the pattern.
Old Nov 12, 2025 | 04:03 PM
N147JK's Avatar
N147JK
I'm getting lost. Am starting over trying a step-by-step method..
1 - using original carrier shims, adjust pinion depth to best align drive and coast side patterns with each other (fore and aft).
2 - use new carrier shim set to set backlash and center patterns.
Old Dec 6, 2025 | 02:10 PM
N147JK's Avatar
N147JK
Here is the latest pattern. Looks exactly like the first one, except with a bit more backlash. I'm thinking this looks good. Backlash is between .006 to .0075. Any comments on this before I close it up and give it a go?
Nightmare90gt
Apr 29, 2024 01:02 PM
slurpeemcflurpee
Mar 4, 2024 02:15 PM
Dave408
Apr 6, 2021 05:46 PM
cbrown9064
Apr 1, 2020 10:48 PM
