Door Edge Guards ?
Old Nov 8, 2025 | 09:05 PM
tbear853's Avatar
tbear853
Door Edge Guards ?
When I had the redo in 2021/2022, I kept my original bright metal door edge guards, but they are beat up by time's ravages. I haven't put them back on my new doors with the new paint as I was sort of concerned they would scrape paint away, but it's been a few years now. I did try some of the chrome mylar aftermarket ones, they don't make the turns into and out of the Dent area without bunching up. I tried some thin white ones, they would not stay put. I found some white silicone rubber stuff in a roll, might try it, and I know there are PPF type strips, but it will yellow as I heard it told.
I might try the clear PPF strips to protect the paint from the OEM metal (after detailing & polishing) as I slide put the originals back over that PPF strip?
With or without, I'm pretty careful where and how I park, so maybe is best without?
Old Nov 10, 2025 | 12:09 AM
tbear853's Avatar
tbear853
Today I picked up a pair of "clear" flexible door guards, kind of rubbery, like silicone maybe. They blend better than black or chrome mylar. No substitute for care, but they'll provide a cushion.
I can just cut one in half and run it from below the dent's lower edge downwards, it'll work.
Old Nov 10, 2025 | 03:35 PM
440 sixpack's Avatar
440 sixpack
I don't believe there is such thing as OEM ones. they were just a common JC Whitney add on's.
If they were original the Marti report should show it . I never ever saw them on a new pickup.
Old Nov 10, 2025 | 04:02 PM
tbear853's Avatar
tbear853
Interesting. I remember Dad had them on a couple new Plymouths, just assumed were offered by Ford too. Judging by the look, they do save door edges a bit of grief.
Maybe these soft ones will too, plus the struck object, What started me thinking of them again was seeing a door opened into a buggy corral rail in front of our H-F store. Wouldn't help in all cases, like that lawyer from up north when I took a ticket and radar detector back to his car for signatures, he had swapped seats with his GF or wife who was driving while I wrote, but whom had gone berserk in a fit. I walked up on the passenger side, was a Mercedes, late at night, tapped the passenger door glass with a knuckle to get her to open up, and she threw that door open before I could reach to stop it hitting my pristine galvanized guard rail. Wrecked the edge of her door as it bounced off. I told her what the guard rail did, and handed her the Escort Elite and she yelled "I don't want it" and it went sailing over the guard rail into the weeds as I jumped back. He got out of the driver side then to look at his car door, and asked me to give her a minute more to calm down, and I told him she had better as if she flung my summons book like that, she was going to have breakfast on the county.
Poor guy.
Old Nov 11, 2025 | 04:40 AM
m78's Avatar
m78
Ford did make a set for the dents. I bought a set back in 2010 from ebay. They're made of anodized aluminum and are so flimsy I don't think it would save the door with a slight impact of swinging the door open. You can see it here.
Old Nov 11, 2025 | 07:17 AM
Kman-S.E.USA's Avatar
Kman-S.E.USA
Here are some after market ones, 8" long, chrome and I don't know if they will fit, but the link is below. Check out their other molding options.
​​​​​​https://www.automotiveauthorityllc.c...d48747c6d56d2c
Old Nov 11, 2025 | 08:52 AM
tbear853's Avatar
tbear853
Yes, anodized aluminum, will scar, and it is a stiff aluminum alloy as they grip well .... and they are notched on the back side so they follow the tight curve to follow the door edge into / out of the "Dent Valley" and over the peak at the rocker area, but keep the exterior and very edge of the door covered ... and while they will not protect door skin wrapped edge from a strong impact that would bend the door, they will protect the door from edge rust caused by chipped paint.
I still have them, they are not bent up either. Just surface scuffs, scratches (resulting from their job over the last 48+ yrs) but wet sanding and a buff will cure that. I do want them back on, but I just don't want to scar or chip the paint putting them on. I keep thinking the right narrow tape wrapped just over the edge with maybe 3/16" exposed first might work.
I was exploring for other ideas or something temporary / easy in the mean time.
Originally Posted by tbear853
Interesting. I remember Dad ... etc ... What started me thinking of them again was seeing a door opened into a buggy corral rail in front of our H-F store.... etc ...
Was mine , but it was a really light bump, more like a tap, was no chips, etc.​​​​​​​ ​​​​​​​
Old Nov 11, 2025 | 11:56 AM
gouger05's Avatar
gouger05
4wd Low
I bought this and put it on my window channels. I had some left over so I also put it on the door edges as my door opens close to a brick wall. It's been working fine for a couple of years and it's cheap.
Amazon - Cowles Chrome U-Channel Guard 18' Amazon - Cowles Chrome U-Channel Guard 18'
Old Nov 11, 2025 | 12:20 PM
tbear853's Avatar
tbear853
Thank You .... Did it follow the bends well? I just looked at my metal ones, more small ding "mini dents" than I recall.
Old Nov 11, 2025 | 01:10 PM
gouger05's Avatar
gouger05
4wd Low
Yeah, pretty good. Probably not perfect, but my truck is far from that. Here is a picture:
Old Nov 11, 2025 | 02:17 PM
tbear853's Avatar
tbear853
Thank You .
Looks great from here, exactly where some others fail.
In my cart now.
Old Nov 12, 2025 | 05:17 AM
m78's Avatar
m78
Looks great. What holds it on ? Package says adhesive, but looks like maybe just friction.
Old Nov 12, 2025 | 11:25 AM
gouger05's Avatar
gouger05
4wd Low
Yeah, it has some kind of adhesive inside the groove, but I think it stays on snug without it. I have removed a piece and put it back on without issue. There was no residue.
Lmhayes88
Dec 22, 2020 08:24 PM
NewEnglandHerdsman
2015 - 2020 F150
17
May 22, 2018 08:47 AM
RenoHuskerDu
Oct 13, 2017 08:11 AM
Brettg27
Escape & Escape Hybrid
Aug 16, 2010 12:11 AM
