Lowering 89 E150
Old Nov 7, 2025 | 09:45 PM
elliote150's Avatar
elliote150
4th Gear
Lowering 89 E150
I want to lower my van, I'm looking for the most drop with the least work, expense, and most importantly, the least effect on the ride. Does anyone have any experience or suggestions ?
Thx
Old Nov 7, 2025 | 11:57 PM
tabijan's Avatar
tabijan
There's this - https://www.ebay.com/itm/267002555754 . They also sell rear lowering shackles or you can have rear leaves recurved.
There might have been drop axles or spindles available in the past but I doubt anything's still available today unless it's a common part with F-series. Something like this - https://djmsuspension.com/product/19...ocks-included/
Maybe a body kit with tighter wheel openings and low hanging rockers - https://www.sarona.com/single_product.php?id=5744 - will make it look lowered:
Sixto
07 E350 5.4 200k miles
Old Nov 8, 2025 | 06:06 AM
manicmechanic007's Avatar
manicmechanic007
I have a ton of experience aligning lowered trucks and vans, doing suspension work etc.
I wouldn't
It sucks to drive around riding the bump stops
The ride suffers the most, the alignment can be solved (sometimes)
You cannot bend the axles easily on those newer style 2x4 trucks and vans
That said, lower away
I'd try to not do anything permanent that will destroy the $ value of the van
You might want to use it as a traveling or cargo van someday
I would buy springs and shocks only, possibly shackles, and not modify the frame
Old Nov 11, 2025 | 09:25 PM
elliote150's Avatar
elliote150
4th Gear
Thanks guys,
I DO NOT want to be singing the "Bump Stop Blues"
I've seen the shorter springs but keep hearing about alignment issues.
Manic, think I will take your advice and not get into the front suspension. You state "possibly shackles" do you have reservations with these?
Thx again.
Old Nov 12, 2025 | 03:45 AM
manicmechanic007
No, shackles in the rear is a good way if you can find some that will work
They need to be shorter to lower the van
Keystoner16
Jun 4, 2017 12:18 PM
Keystoner16
Aug 26, 2015 12:27 PM
69econoline
Apr 21, 2013 08:41 PM
BrokeNeckGroup
Jul 22, 2012 10:56 AM
