p2150 help please
Old Nov 3, 2025 | 03:54 PM
Thamaxx118's Avatar
Thamaxx118
4th Gear
Question p2150 help please
I am working on a 2022 f450 6.7 it has p2150 I did an ohms test at injectors and they tested about same 181.5ohms
Its missing on cyl.6,8.I can't find a connector pinout at the ecm to test wiring .This is my first post ever sorry if confusing
Old Nov 3, 2025 | 05:41 PM
muisejt's Avatar
muisejt
P2150 Fuel Injector Group "B" Supply Voltage Circuit Low - This DTC sets when a current differential between the fuel injectors power circuit and the fuel injector ground circuit is outside a calibrated limit. When diagnosing a fuel injector circuit concern, this DTC refers to cylinder numbers 3, 6 and 8.
http://cimg3.ibsrv.net/gimg/www.ford...ee67acdadb.jpg
Fuel injector connector
http://cimg4.ibsrv.net/gimg/www.ford...ca59f08923.jpg
PCM center connector
http://cimg5.ibsrv.net/gimg/www.ford...5dca375800.jpg
Last edited by muisejt; Nov 3, 2025 at 05:58 PM. Reason: pictures where not working
Old Nov 4, 2025 | 02:59 AM
Thamaxx118's Avatar
Thamaxx118
4th Gear
Thumbs up
Thank you that should be perfect.
Old Nov 6, 2025 | 03:43 PM
Thamaxx118's Avatar
Thamaxx118
4th Gear
Question muisejt , Aren't the injectors normally closed (I should get an ohms reading?) I checked one day and i got the 181.5 at injector .Now it still starts and runs but when i unhook center plug i get all open and if i unplug injectors i get nothing (i have a test plug and using a fluke with needle points and set to ohms. lol
chasteen1156
35
Nov 5, 2025 09:37 PM
parrisw
22
Nov 25, 2008 08:10 AM
97 HD
Oct 23, 2007 06:24 PM
johnguc
16
Oct 30, 2006 06:35 PM
mtgrzlyman
18
Sep 6, 2006 10:04 PM
