Tpms Sensors
Old Nov 1, 2025 | 11:28 AM
JDJR59's Avatar
JDJR59
Tpms Sensors
I just took the tires off my 2019 f250 and put them on my 2026 f250. I now have a tpms fault when I start truck. Tried driving 30 miles. no change. Then I did the flasher 3 times went over and started to let out the air on front left tire. almost flat and no horn beep. Is there a learn tool I can buy or do I need to go to the dealer? Also is there an issue between 2019 sensors and 2026 truck
Old Nov 1, 2025 | 11:49 AM
Stiletto364's Avatar
Stiletto364
If my memory is correct, I'm pretty sure the 2019 trucks used 315MHz sensors, and the 2023+ trucks moved to 433Mhz. The TPMS receiver's frequency in the 2026 truck is incompatible with the 2019 sensors. I'm thinking you're going to need to upgrade all the 315 MHz sensors to 433 MHz if you want to use them on the 2026 truck. There is no reconfiguration or adjustment by the dealer or by you that would be able to work around replacing the sensors.
Old Nov 1, 2025 | 12:44 PM
Tsax6010's Avatar
Tsax6010
This is my understanding as well
Old Nov 1, 2025 | 05:55 PM
FOURBYBUD's Avatar
FOURBYBUD
This is fact!!!! 2024 and up use the higher frequency.
Old Nov 2, 2025 | 05:05 AM
2022FordSuperduty's Avatar
2022FordSuperduty
Trailering
I can confirm what others have stated. I swapped out 22 BAP wheels into my 24 and they would not sync. Had to update the sensors.
Old Nov 2, 2025 | 05:27 AM
techrep's Avatar
techrep
thought it was 2023 and up for 433 mhz
Old Nov 2, 2025 | 06:35 AM
Tsax6010's Avatar
Tsax6010
I think it was a mid year 23 change
fatcat265
2023+ Super Duty
May 9, 2026 08:26 AM
Xbolt
2021+ F150
Nov 11, 2024 09:37 AM
Phillbo
Apr 30, 2024 04:28 PM
DET17
Feb 27, 2022 11:55 AM
_red rocket_
6.7L Power Stroke Diesel
17
Feb 18, 2015 06:34 PM
