Forscan Profiling issue
Old Oct 31, 2025 | 08:29 AM
WagyuRancher's Avatar
WagyuRancher
1st Gear
So I'm new to Forscan, but i have a 24 F350 6.7 HO Platinum. I was wanting to get rid of all the nanny alarms but when I got the profile for the truck and was going through the options in the modules, It shows that it's Gas, not Diesel and there was a couple other oddities that seemed wrong. Is this normal? I didn't want to make changes because the information in the modules seemed to be wrong.
Old Oct 31, 2025 | 10:37 AM
powerboatr's Avatar
powerboatr
profile from where?
If you open forscan, and let it load up the truck profile it will ask ?
If its correct.
Sometimes forscan has glitches from obd not seated correctly etc
And or battery low and not all modules load correct
Put a charger on,
Reset the obd and USB in the computer and try again
If it continues
Reach out to rhe guru in the forscan thread,
Old Nov 2, 2025 | 08:05 AM
roadpilot's Avatar
roadpilot
It should download everything from the truck to create a profile. Make sure you're not loading an old profile from a previous truck. Delete all profiles and connect again.
Or are you saying, once downloaded, it has the wrong info?
MNBenny
Nov 3, 2023 02:26 PM
kball
Oct 26, 2023 06:58 PM
zeke37
Sep 16, 2018 10:34 AM
ford216
Jun 20, 2018 03:03 PM
Peteraceboat
Mar 29, 2011 06:55 PM
