Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
View Poll Results: Huh
Yay
0%
Yippee
0%
Sweet
0%
Awesome
0%
Voters: 0. You may not vote on this poll
1968 C600 Vin lookup/piston source
Old Oct 30, 2025 | 11:51 PM
fambam917's Avatar
fambam917
6th Gear
Hello i need to figure out exactly what year and model ford this is, its and old utility truck, i believe its a c 600? I know it has a gas 330 engine with manual trans. Here is the VIN
C61CUD44572
what dam year is it????? Thanks!
Old Oct 31, 2025 | 01:32 AM
85e150's Avatar
85e150
Welcome to FTE!
Yes, C600 with 330. I'll get back to you tomorrow on the rest. Figure '60s for age but I need to look at the serial number list to be sure.
Old Oct 31, 2025 | 10:02 AM
fambam917's Avatar
fambam917
6th Gear
Thanks! Also where would i find the best service mznual for this thing? After we verify the year.
Old Oct 31, 2025 | 12:53 PM
85e150's Avatar
85e150
C61CUD44572
C61 = C600 gas
C = 330 2V MD FT gas V8. Medium Duty uses FE crank and distributor drive, possibly water pump.
U = Louisville Assembly Plant
D44572 = 1968 numerical series, June 1968 production
Beware of widowmaker wheels.
https://www.ford-trucks.com/forums/8...l#post19892682
Brake parts are available but there are no new drums available.
Shop manuals can be found on line:
https://www.forelpublishing.com/
Or used paper & CD copies:
Amazon Amazon
https://fordmanuals.com/product/1968...Z6YPQBuQHJjjJU
And on and on and on if you do a search for "1968 ford c600 shop manual".
Old Nov 1, 2025 | 10:43 AM
fambam917's Avatar
fambam917
6th Gear
Thank you very much, i ordered a manual from the site you suggested. Thanks!
Old Nov 29, 2025 | 05:11 PM
fambam917's Avatar
fambam917
6th Gear
Piston size for a 1968 ford c-600, 330 ci medium duty engine
Hello, i got a bad piston in this old piece of yard art, 1968 c 600 with 330ci medium duty, need to order a new one, i took t gauge readings at multiple bore locations and measured 3.9005
what size piston and rings should i get? Its being used as a flat bed utility truck to haul ****, not a hot rod. Im
just replaci g this single piston, and any ideas who may stock such a piston?? Thanks!
Old Nov 29, 2025 | 08:13 PM
85e150's Avatar
85e150
I merged your threads as you're not going to get much traction in the pickup forum on this subject and you already had your decode here. I don't know what your poll was about but.....
The listed bore for a 330 is 3.875". So at 3.9005 you have a possible .0255" piston clearance. This does not compare favorably with the OEM spec of .0025-.0033".
You will have a piston slapping oil burner if you don't already.
So say you put in a new standard piston. It might break on start up, or it might bang around for a while.
Or you go .040 for under $100 plus rings:
https://www.ebay.com/itm/386176213552
Note that appears to be a 4 ring piston. There are pics, and other 330 FT pistons shown if you scroll down the page. Are yours 3 or 4 ringers?
Higher price:
https://www.summitracing.com/search/...CD_w1PhSyo1OV2
You might find singles on e-bay but most of the time you'll be buying a set. No one wants 7 pistons laying in the bin.
If you went even .030 over, and for certain .040, you need to have the block bored. You could spend a week with a hone I suppose, but by the time you get done with that you'll have a pretty good mess of grindings all over.
Or you could just look for a used 330 or 361 and slap it in there.
Old Nov 29, 2025 | 09:33 PM
fambam917's Avatar
fambam917
6th Gear
Its a 3 ring. 2 compression ring grooves, and an oil ring groove. Thanks for the links to summit and ebay. I really just need 1 piston and unfortunately summit wants to sell me all 8 of the .020 over pistons. Know of any junkyards that have a collection of these trucks or 330 engines?
Old Nov 29, 2025 | 10:21 PM
asavage's Avatar
asavage
You can't hone an oval/tapered bore round and parallel, and bores wear both oval and tapered. If the above numbers are real, you'll need to start over with another FT engine, or plan on a rebore.
[later]
Most telescoping gauges don't resolve to .0005" (unless you've got serious high-end metrology equipment). How certain are you about that 3.9005"?
HiBoyCC
Nov 3, 2022 07:33 PM
Rickyrobert
May 21, 2017 05:05 PM
Jay Fletcher
Apr 22, 2003 08:33 AM
Willie
Aug 28, 2001 03:53 PM
