Fuel filter replacement
Old Oct 31, 2025 | 10:27 AM
Max Capacity's Avatar
Max Capacity
I guess we have to wait until the OP gets home from work... I know us old retired guys have too much time on our hands sometimes... but at least we want to help. It can be frustrating having to wait for updates...
Old Oct 31, 2025 | 12:54 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by kr98664
One more caution. Reading between the lines, you’re new to a carbureted engine and mechanical fuel pump. If the carb is indeed empty, you will need to crank the starter a bit to get fuel up to the carb. This is perfectly normal.
However, be careful not to use the “crank and pray” method. Don’t just crank and crank and crank that poor starter. If fuel is not reaching the carb within 20 seconds or so, stop cranking and investigate why. Let the starter rest for several minutes before trying again.
Sadly, we’ve had too many tales of guys running down the battery or burning up a perfectly good starter. If you don’t get the desired result, continued cranking of the starter isn’t going to change anything. Stop and investigate why.
That is why I said to give it a spray of starting fluid. When it wants to start it is spinning faster so the fuel pump will fill the carb faster if it works.
If it did not fill on the first "fire of life" hit it with a 2nd spray and see if that does it.
If they let us know where they are we might be able to swing by to give a hand.
Heck if they were not there leave the keys and we will get it running for when you get home
It is really hard for us because what we call a part or what the truck is doing could be something totally different than what you are calling it.
Like it will not crank by when it turns over it??? crank & turn over are the same thing. Wanting to start but will not run I see it as it being just as you let the key off from cranking because it should run but dose not.
Yep not being there to help kills us a little
Dave ----
Old Oct 31, 2025 | 02:11 PM
BigBlue2's Avatar
BigBlue2
Chiltons manual suggests having the tank half full when working on the fuel system and air has gotten into the fuel line to aid in priming the mechanical pump.
Old Oct 31, 2025 | 03:15 PM
Gutsnglory's Avatar
Gutsnglory
4wd Low
You do not need to do any special procedure to get the air out. The fuel system will fill on it's own from cranking the engine. Check the carb for fuel like was mentioned by taking the aircleaner off, manually open the choke door on top of the carb, and take your other hand and push the throttle wide open. This is all done with the engine off. You should see one single stream of fuel squirt into the engine. If you do, you have fuel. If you don't see fuel, crank the engine some. Then go out and check it again.
I took videos but they are too big to post here it seems. It was not squirting fuel into the carb with a pedal press. I tried to have it cranked and the first time it looked like it was leaking some fuel below the carb area. Was hard to tell cause the moment I noticed it, I wasn't there and called for it be stopped. Tried 2 times after but didn't happen again. Also, in between and at the end I checked for fuel on a pedal pump but saw none. 3 cranks for about 10 to 15 seconds a piece with about 2 min in between. I'll say initially I removed the fuel line from the filter to see if a pump from the pedal would produce fuel but I got none, then read this comment and proceeded to do the cranking stuff. The fuel looking like it was coming from below the carb is concerning but hard to say the origin cause it just went all below it. Cleaned up best I could. It was running well enough before all this I will say though like I said in the post, it was being sluggish on a light pedal press.
Old Oct 31, 2025 | 03:19 PM
Gutsnglory's Avatar
Gutsnglory
4wd Low
All good information so far.
I would start, motor off, by opening the choke looking down inside and move the throttle and see if you see fuel squirt and if not you can either spray a little starting fluid down inside the carb and see if it will start.
Or keep cranking it, may take a bit of cranking to fill the carb fuel bowl.
I have to crank my motor, a 300 six like yours, a lot when it sits for a bit to fill the carb bowl. I also pump the throttle like a mad man when cranking till it comes to life.
If you still are not getting fuel to the carb, even with starting fluid 2 or 3 times you will need to look into why now fuel to the carb.
I would undo the hard line from the screw in filter. BTW you turned it in to far. It uses pipe threads that have a taper to no need to "run it home" till tight. You cant loosen it now as it will leak and hope you can use a new filter down the road and not have it leak. Once the hard line is loose have something to catch fuel out of the line and crank the motor and see if fuel comes out.
If not report back and we can go from there on what to check.
Oh if you have been moving the throttle a lot you may have flooded the motor. If you think that is why it will not start and see fuel squirt then try holding the choke open with a large screw driver, hold the throttle to the floor and try and start.
Dave ----
ps every motor with a carb starts a different way, 1 pump or 2 or none when cold or hot. That is all the fun of owning something old
I replied on another person explaining what I did. Doesn't seem like it's getting fuel to the carb. I did try a couple cranks to nothing. Maybe still needed to do a few more but I am hesitant to push anything too much or atleast what feels like too much.
Gutsnglory's Avatar
Gutsnglory
4wd Low
Dave ----
Old Oct 31, 2025 | 03:24 PM
Max Capacity
Fuel below the carb. We'll want to know if you mean from where the carb mounts to the intake manifold or are you saying it's from under the fuel supply line feeding the fuel filter ?
With the fuel supply line removed from the filter, you'll want to crank the engine over for a few seconds and see if gas comes out of the line. You may want to put a hose over the tube into a bucket on the ground.
Those of us who have been around cars for years would just give it a quick crank of the starter and see if any fuel spits out. You just need to verify the fuel pump on the engine is working.
There is a rubber piece inside the pump that if bad could give less fuel to the engine until it doesn't...it's been many decades since I've had a mechanical fuel pump.
Old Oct 31, 2025 | 03:52 PM
Gutsnglory's Avatar
Gutsnglory
4wd Low
the fuel appeared below where my finger is pointing. Only happened that first time but not again. I even did try swapping to the old filter and gave it a few cranks but no. There is fuel coming in the line though. I'd have to try what you said and get it out to see but when I removed the line to swap to the old filter, fuel came out.
Old Oct 31, 2025 | 03:57 PM
Max Capacity
So fuel came out of the line and the bottom end of the filter.
Are we sure fuel is coming out of the top of the filter when it's connected on the supply line ?
We're heading out for dinner soon... so others may have to reply.
Old Oct 31, 2025 | 04:20 PM
kr98664's Avatar
kr98664
Maybe I can help. You stay home and keep going with the troubleshooting. I’ll go ahead and eat your dinner for you.
Old Oct 31, 2025 | 06:42 PM
Franklin2's Avatar
Franklin2
Do you think you would be up to taking the carb off and tearing it apart? Or buying a china knock-off carb off Amazon and sticking it on? I would imagine you have just got dirt in the carb and it's clogging it up. But you will have to take it apart and put a kit in it to fix it.
Old Nov 1, 2025 | 12:11 AM
Rusty_S's Avatar
Rusty_S
If you have fuel at the hardline at the carb, and at the filter itself. It sounds like the needle and seat might be stuck and not letting fuel to enter.
If you feel inclined and you have a light 2 lb or less brass hammer, I would lightly tap by using the weight of the hammer around where the fuel comes in, not the filter itself but the sides of the bowl near where the filter comes in, this is roughly the area the needle and seat will be situated at.. Sometimes youll get lucky and the jaring will free the needle that is stuck and youll be good. If that is what it is and the needle unsticks I would strongly recommend adding some stabil 360 ethanol fuel treatment if you have E10 fuel at all your pumps like here. It will help clear the system out and hopefully prevent it from sticking again.
I dont have a photo of it but I just dropped the tank on my truck that I was running that stuff in with every fill up, truck sat for the last 5 years since the engine went down and I parked it. Fuel tank is empty now in typical fashion with sitting a long time but that ethanol treatment did its job, the inside of that tank isnt a rust bomb like I have seen tanks sit just 1 year without any kind of ethanol treatment.
Old Nov 1, 2025 | 08:06 AM
  #28
Gutsnglory's Avatar
Gutsnglory
4wd Low
what do you mean by needle? Is this needle between the filter tip and the carb?
Old Nov 1, 2025 | 08:21 AM
  #29
Franklin2's Avatar
Franklin2
Have you ever done any plumbing? Ever work on a toilet? Your carb works the same way. The large square portion of the carb is hollow, like the tank on your toilet. It stores gasoline like the toilet stores water. To control the level of water in the toilet tank you have a valve and a float. Your carb has the same thing, a float and a valve to control the gasoline level inside the bowl of the carb. When the carb bowl is full, the needle valve shuts the fuel off that is coming from the pump. The pump still works, it just pushes the fuel against this needle till the level in the carb bowl drops, the needle is hooked to the float, and the needle opens and lets more fuel in.
You have many things working against you with this simple system. The main thing is the fuel the government makes you buy. It is lousy, and in a engine that sits around, it gets gummy and sticky. The ethanol in it attracts water and that makes the fuel tank rust. This rust flakes off and gets sucked up by the pump and gets stuck in the carb, clogging it up.
Old Nov 1, 2025 | 08:39 AM
  #30
Max Capacity
This is one of the many pieces inside the carb.
https://www.google.com/search?q=carb...client=gws-wiz
