Newbie questions
Old Oct 30, 2025 | 11:27 AM
ArticTheWolf's Avatar
ArticTheWolf
Newbie questions
First things first I’m new here so hi with that being said though I have some questions with the OBS’s as I’m a fan of them and plan to get one in the future
first 99-04 super duty axles are they just a direct bolt in springs and all? I saw a yoke adapter somewhere too (I know 05+ coil swaps exist I just prefer leaf springs I’m odd like that) also when swapping the rear axle with a 99-04 super duty what will I need exactly to make the rear disc brakes work properly? I’ve heard just as is is fine or I’ll need an adjustable brake valve or I need to swap in the super duty brake cylinder and servo (whatever it’s called) You’ll have to explain it to me like I’m 5 because I’m trying to understand this stuff lol
second has anyone been able to put a brush guard on an OBS that had its front bumper swapped with a super duty’s? (I.e 2017-2022 super duty’s)
Old Oct 30, 2025 | 12:25 PM
knottyrope's Avatar
knottyrope
Front springs will bolt in if you get an RSK kit as the SD prings are longer
https://www.pmfsuspension.com/1992-9...-Kit_p_13.html
Rear springs should be fine.
Rims wont fit from OBS so factor that in.
Going hydro boost? Thats what SD usually have in them.
You will need the proprtioning valve for them to work well and then decide on keeping RABS or not.
Dont know about the bumper but others will chime in.
Old Oct 30, 2025 | 01:10 PM
ArticTheWolf
RABS stands for what? Rear ABS? Also if the springs bolt in just fine that mean the super duty axles do too? Just making sure
should I also get a RSK for the rear? Considering I’ll need one for the front and that’ll lift it by a minimum of 2” (or if there’s some way to squeeze the front super duty springs in without an RSK which I doubt) or something else so it’s not just a squatted truck then lol
and yes hydro boost from a super duty maybe
Old Oct 30, 2025 | 01:28 PM
knottyrope's Avatar
knottyrope
Rear Abs aka RABS
95-2003 are all Sterling in the F250 and F350
Rear is already set with rear shackles.
The springs on OBS are shorter than SD ones so you cant squeeze them in.
There is no short cut on lifting. IMO get the springs you need to lift it properly.
Old Oct 30, 2025 | 03:15 PM
ArticTheWolf
so just get a 2 inch lift leaf spring for the rear to match the front? dont go with a RKS at the rear?
Old Oct 30, 2025 | 03:27 PM
knottyrope's Avatar
knottyrope
Springs or blocks for the rear
there is no RSK availble for the rear since its already been done
A front shackle causes the axle to move forward and the spring to compress, which can feel harsher, while a rear shackle allows the axle to move backward, improving ride comfort and bump absorption. A front shackle is often found on stock vehicles and can improve the approach angle but results in a rougher ride, whereas moving the shackle to the rear is a popular modification (shackle reversal) for a smoother ride
Old Oct 30, 2025 | 03:31 PM
knottyrope's Avatar
knottyrope
good read for you
https://www.ford-trucks.com/forums/1...sel-truck.html
Old Oct 30, 2025 | 03:35 PM
ArticTheWolf
oh ok i got you for some reason i was thinking a shackle reversal was FLIPPING the shackle upside down lmao but after reading what you said and looking at pictures i see what you mean basically making the front leaf spring mount which had the shackle and was the moving part while the rear was just a solid mount basically swapping them around making the rear the shackle holder and moving part while the front is the solid mount thanks so much for helping me understand that
Old Nov 1, 2025 | 05:57 AM
97-psd's Avatar
97-psd
Help me understand what you are working with.
you have a 2003 truck that has good engine and drive train but the body has some rust?
you do not have an OBS, but want to buy one and swap a bunch of super duty parts onto it?
why not fix the SD? Body parts are cheap compared to buying a truck then swapping a bunch of parts onto it.
If you had an OBS already that needed work then maybe in the right situation it would make sense. But I am not sure it does currently.
If I understand this correctly, then save yourself a ton of time and money and fix the super duty.
Old Nov 1, 2025 | 06:46 AM
ArticTheWolf
the super duty isn’t worth the effort to try and fix it up all around it’s a rust and rot bucket it’s on its last legs in general the engine of it while it has a leaking oil pan and a hole in the headers it still runs strong basically what I’m saying is that it’s just- not worth the time or effort to try and fix it up with a cab swap and all that (besides the frame is all scaled up the thing wasn’t taken care of in the rust department) the axles are rusty yes but they’re not gone so they can be fixed up the engine still has good parts minus the oil pan so I mean idk- in my head it just kind of makes sense I’m also probably not explaining it right 100% so that’s my bad….
Old Nov 1, 2025 | 08:04 PM
97-psd's Avatar
97-psd
Ok. That helps some. I am still not sure you will gain a lot. If you pick up an obs some of that stuff won’t help that much. All you gain with axles is rear disc brakes. Unless the OBS is 2wd then the juice really isn’t worth the squeeze just to swap 4wd axles.
lit is a tough spot to have parts and want to put them on something. Have you thought about doing something more fun? Like a dent side swap? That would be more fun and the parts would net a larger benefit for the truck.
Old Nov 1, 2025 | 08:15 PM
ArticTheWolf
i havent considered a dent side swap but that's mainly due to budgeting issues i have doing the route i want to do with the OBS seems like a cheaper option- yes it wont really net me a large benefit but i honestly just adore the look of an OBS and i feel like it'd be fun to do this kind of stuff on a truck im familiar with (my brother for reference has 2 bronco's and 2 f350's lol) idk- that's just me honestly for the 99-04 SD swap i know i'd need a front RSK so that gives me some sort of benefit there idk part of me kind of see's it as a slightly lesser 05+ axle swap in a way not saying you're wrong btw mind you
Yorid
2023+ Super Duty
48
Dec 28, 2024 02:29 PM
VA86ft
Oct 8, 2022 08:50 AM
Patrick4451
Mar 28, 2020 07:53 PM
Ford Trucks
Official Ford Forum : Ask an Engineer
104
Sep 13, 2016 10:15 PM
