I am jumping in to my first diesel rebuild for my 2002 F350 Crew Cab DRW Auto Transmission. My OE cam looks pretty good but while i'm in there, i was considering an aftermarket cam. I am doing an essentially stock rebuild. Truck gets lots of highway miles and don't pull heavy very often. I don't intend to do a lot of power upgrades for fear of compromising durability and reliability. Better fuel economy is a concern.
For a 7.3 build there is no need of a camshaft. It's all injectors and turbo and tuning. Diesel is a very different world than gas.
Cams matter in gas engines that rev high. 7.3 will max out at like 3500 RPM.
Gas engine needs cam time open to allow more air/fuel. 7.3 you simply inject more fuel with bigger injectors with tuning to match. Then get enough air for proper combustion with more turbo.
The biggest difference is that a diesel engine has to build a whole lot more cylinder pressure than a gasoline engine, else it won't run. A diesel camshaft's specs look like the most conservative gas camshaft you could imagine- short duration and little overlap, but that is required to build pressure. Increasing duration and overlap like one would do in a gas camshaft would likely result in a diesel engine that likely would be very difficult to start, if it would even run. Increasing lift could theoretically help but with the infamously horrendous flow in the 7.3 PSD heads (110 cfm or so, that's a third of what stock 7.3 Godzilla heads flow) I would be surprised if there's any power added from a cam swap. However more airflow from the turbocharger will overcome all of that and much more...
Stick with a stock camshaft....however I faintly remember they are no longer available which is why more are asking, but I could be extremely mistaken.
I run a colt cam and I can tell you I lost bottom end torque over a stock cam. You will not get any of the gains claimed from these cams...they don't help egts, fuel economy etc.
As mentioned, upgraded springs/ push rods is worth it
If you wanted to do something dumb like spin this thing to 4500rpm yeah, a cam swap might help, but you'd be in it deep trying to get enough fuel in the hole to make torque at that speed with HEUI sticks.
that is nice feedback on the Colt cam. Few have ran it and fewer have given good feedback on how it does.
if the truck will be fairly stock, then the stock cam is the best option.
