camshaft???
Old Apr 23, 2008 | 11:03 AM
strokin'_tatsch's Avatar
strokin'_tatsch
camshaft???
i have a buddy looking for an aftermarket camshaft for our trucks.. does anyone make a cam for the powerstroke?!?! i can't find one anywhere yet. i though crane made a cam for these things? anyone know where to find an aftermarket cam? we have been thinkin' of what these trucks could do with a good camshaft and so he wants to try it out. its gonna be a long night once we do find one and install it....
Old Apr 23, 2008 | 11:21 AM
tjbeggs's Avatar
tjbeggs
Not much to be gained from a cam on diesels. there are a few custom grind cams out there but they are big money from what I understand. Mostly guys that are sled pulling and dragging their truck only. I don't think there are many daily drivers out there with different cams.
Old Apr 23, 2008 | 11:25 AM
strokin'_tatsch
so where can we get a cam for it? he wants this truck to haul major a$$... he is on the whole mix the air and fuel perfect and we are thinking a cam will help with that a little more also. i prefer adding a ton of fuel and saying hold on, but he wants to try out a cam for his... so i'm just trying to help him find a place to get one.
Old Apr 23, 2008 | 11:34 AM
tjbeggs's Avatar
tjbeggs
I have no idea. Check with Blackwidow diesel performance or Diesel innovations. Probably would have to call them. What mods does your friend already have? BTW if he want the fuel and air mixed perfect you should remind him that the PSD is a direct injection engine. Mixture has more to do with fuel injectors, turbo and piston design than cam shafts. He is thinking about gas engines. Diesels are totally different.
Old Apr 23, 2008 | 11:48 AM
secondarychaos's Avatar
secondarychaos
X2 on that last part by TJ.
The only real benefit of a cam is a small reduction in EGT's, and maybe a few horses...
Not worth it for the money, unless you're talking about going past the 500 or 600 hp mark, IMHO.
If you want to tweak fuel to air ratios in these trucks, do injectors and a chip, and let your engine breath.
Old Apr 23, 2008 | 12:28 PM
strokin'_tatsch
yeah, i agree with all that tim. he has a big chip in it right now, diy intake that i put on it, and exhaust. that's it. i told him that if he wanted more power then go with diy injectors and some different tunes, but he doesn't listen to anything i try to tell him. this is his first diesel so he is slowly learning like i have. i told him to do all he wanted with the cam and everything and i will just do fueling enhancements with injectors and a dp-tuner and we will race and see which one truly has more after it's said and done... he was all for it, but i will keep trying to get him into the fuel side of it rather than cams and stuff. thanks guys
Old Apr 23, 2008 | 12:33 PM
tjbeggs's Avatar
tjbeggs
Well he will figure ir out when he drops a grand and doesn't have any thing to show for it other than his stock cam laying on a shelf.
Old Apr 23, 2008 | 01:53 PM
strokin'_tatsch
yeah, like i said. i will keep on him about the fuel instead of the cam. i personally can't wait to put my stage 1's in here so i can show him that when you add more fuel you will also get more air as well. right now i get 20 psi of boost and after the injectors i should be around 30psi. he will believe me once he sees it...
Old Apr 23, 2008 | 01:55 PM
Neal 97 250's Avatar
Neal 97 250
I guess it could be a twirling batton. Or a practice bat since it heavy. LOL
Old Apr 23, 2008 | 02:25 PM
FFemt5287's Avatar
FFemt5287
hehehe, twirling batton.....
on a more serious note, tell him to become a member here and read around for a while. he will quickly be pointed in the right direction as i have been (and still am being). im another vote for "waste of money" unless he has nothing better to do with it. i once had a $30k list made up of things for an engine built from the block up and i was quickly educated to the many many expensive flaws of the list for big horsepower. the cam was one of them (hypermax, btw). ive pretty much got the list to under $20k now thanks to these guys. get him on the boards!
Brandon
Old Apr 23, 2008 | 02:32 PM
tjbeggs's Avatar
tjbeggs
Ah hypermax!! thats right!
Oh BTW I have always want to make a lamp out of a Cam shaft. bore a hole in the center to runt he cord and the shaft would be the base and stem of the lamp. it would look great in my office!! I have also used 4 350 pistons and rods to make an end table. Two tiered and the pistons and rods where the supports for the second tier. looked great but was it heavy!
Old Apr 23, 2008 | 02:58 PM
FFemt5287's Avatar
FFemt5287
Tj, V-6, 8, 10, 12, 16, etc. short block, feet welded to the bottom, piece of glass over the top, viola! gearhead coffee table!
been mulling that one over for a while, but i figure it wouldn't fit mom's country home motiff she's got going on here, lol
Old Apr 23, 2008 | 10:50 PM
lukecline's Avatar
lukecline
beans diesel has a cam or two available, Hypermax, DI and maybe one or two more out there avail that i cant remember.
Old Apr 24, 2008 | 05:31 AM
tjbeggs's Avatar
tjbeggs
Luke are you running stock cam or aftermarket?
Old Apr 24, 2008 | 07:51 AM
helifixer's Avatar
helifixer
I have had custom cams cut by comp cams for gas engines, they might cut them for diesels.
