Valve lash issues
Old Oct 29, 2025 | 10:44 AM
David7's Avatar
David7
4wd Low
Valve lash issues
I have a 302 motor in a Ford 67 f100. I do not know how old the motor is. The valve lash caps that are on the motor are destroyed, which is causing excessive valve lash clearance. I cannot adjust the rocker nut down tight enough to get three-quarter turn after the point of zero lash.I’m looking at replacing the push rods and the rocker arms with roller tip rockers,because the rocker arms are worn. I looked into this because I’ve been having serious valve chatter. does anybody have any suggestions. It’s my understanding that these original valve lash caps are no longer available. My valve stem diameter is .286.
Old Oct 29, 2025 | 12:16 PM
blue68f100's Avatar
blue68f100
Possible cam going flat.... From using the wrong oil...
Old Oct 29, 2025 | 12:44 PM
davelj's Avatar
davelj
I see those factory lash caps for sale on Ebay occasionally. They generally sell for more than a replacement valve that doesn't use a cap.
Old Oct 30, 2025 | 02:33 PM
fe390pc's Avatar
fe390pc
I would look at doing a valve job before throwing roller rockers on there. You may be throwing money away if the heads/valves aren't in good shape.
Old Oct 30, 2025 | 02:48 PM
charlie g's Avatar
charlie g
FTE Community Team
with above, start digging deeper into the problem, before throwing parts into it
R/S85
Dec 31, 2018 08:50 AM
sicdefused
Aerostar
Mar 30, 2007 05:00 PM
adunham
Jul 5, 2006 08:27 PM
72earl302
Nov 5, 2004 02:28 PM
