Modular V10 (6.8l)
3v Problem Areas
Old Oct 28, 2025 | 08:46 PM
obsxl's Avatar
obsxl
3v Problem Areas
Just recently picked up a 2008 super duty with the v10 and have been reading about some of the problems they have. Aside from the common exhaust leaks and factory spark plugs breaking, it seems like they had issues with the roller rockers failing during some years, and also suffered from insufficient oil pressure to the top end, especially at idle. Are either of these issues (or any others) something I should be concerned about? Did certain years have issues or is it all 05 and up engines? Thanks
Old Nov 2, 2025 | 04:18 AM
charlie g's Avatar
charlie g
FTE Community Team
only big issues i know of on the 3 valve , were the 2 piece spark plugs and exhaust studs snapping ,
Old Nov 4, 2025 | 10:41 PM
obsxl's Avatar
obsxl
that’s what I thought too but after reading some more, it seems like the top end can have issues, especially with high idle time
Old Nov 13, 2025 | 10:09 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Interesting, I haven't seen that with Ford V-10s, can you point me at what you found?
Old Nov 19, 2025 | 02:59 AM
obsxl's Avatar
obsxl
From what I’ve read, the 3v v10s suffered from some of the same issues the 3v 5.4s did. Mainly low oil pressure at idle with the stock oil pump, and the roller rockers failing (due to lack of oil or just bad?) and wiping out cam lobes. I also saw a thread a while back about a fleet manager having a bunch of v10 trucks failing, and I think he found that the timing chain tensioner seals were leaking and losing oil pressure causing the failures, also common on 5.4s. The v10 uses the same rockers, lash adjusters, and timing chain tensioners as the 5.4. Ford updated the rockers at some point but I’m not sure what all years of the 3v v10 were prone to issues, maybe all? I’m sure keeping good oil in them and not letting them idle excessively probably helps.
Old Nov 19, 2025 | 09:31 PM
CathedralCub
FTE Community Team
I'd say keep good oil in it, change it ahead of schedule, don't beat it all the time, and it will probably be fine for you for a long time.
Keep in mind that a lot of 5.4s and most 6.8 V-10s saw hard lives with less than stellar maintenance.
Old Nov 20, 2025 | 03:17 AM
charlie g's Avatar
charlie g
FTE Community Team
this old thread may help https://www.ford-trucks.com/forums/1...-failures.html
Old Nov 20, 2025 | 01:57 PM
obsxl's Avatar
obsxl
yep that’s the thread I was referring to
Old Nov 20, 2025 | 04:09 PM
DesertSmoker's Avatar
DesertSmoker
That old thread is relevant to 2011-2015 F-450s F-550s and so on. Not really relevant to any 2010 or older v10.
Old Nov 21, 2025 | 10:55 AM
charlie g's Avatar
charlie g
FTE Community Team
while the OP states 2011 to 2013 that thread pertains to the 3 valve 2005 and newer .and in all regards since the v10 is really a 5.4 with 2 extra holes, sharing a lot of parts,what goes wrong in a 5.4 can possibly go wrong in a v10
Old Nov 21, 2025 | 10:18 PM
CathedralCub
FTE Community Team
Cam phasers can't go wrong in a V-10, but yeah otherwise there are a lot of common parts.
Old Nov 25, 2025 | 10:04 AM
super 6.8's Avatar
super 6.8
How many idle hours is your truck showing?
I always refrained from extended idling but if it was necessary I did the high idle mod to help compensate some.
From what I read it is a real issue but to what extent is hard to say.
Old Nov 26, 2025 | 01:01 AM
obsxl's Avatar
obsxl
I don’t think pre-2011 trucks show idle hours do they
Old Nov 26, 2025 | 05:38 AM
charlie g's Avatar
charlie g
FTE Community Team
my 05 did,
Old Nov 26, 2025 | 12:46 PM
obsxl's Avatar
obsxl
mine only shows engine hours, 4180hrs with 149k miles
