Transmission problems
Old Oct 28, 2025 | 09:58 AM
Shawn_Blankinship's Avatar
Shawn_Blankinship
8th Gear
All gears are forward besides park. What can I do to fix it or should I just get a used one and replace it?
Old Oct 28, 2025 | 11:13 AM
tbear853's Avatar
tbear853
We might need a better description.
Are you saying reverse goes forward, is neutral forwards too.
Old Oct 28, 2025 | 11:28 AM
Shawn_Blankinship
8th Gear
Yes. Reverse and neutral go forward as well. Yesterday when I went to the gas station to fill up my O/D light started flashing and it said trans fault on the cluster where it shows the milage. Then this morning I went to reverse and it went forward so I put it in neutral thinking I would roll backwards but it also went forward.
Old Oct 28, 2025 | 03:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If park still holds the truck, then most likely the forward clutch has welded itself together. It's time to replace or rebuild the transmission.
Old Oct 29, 2025 | 08:35 PM
Shawn_Blankinship
8th Gear
Thank you for your time and help. I guess I need to remove this one and replace it. How difficult is it to rebuild myself? I'm pretty mechanically inclined but I typically don't mess with transmissions so it'll be a new one for me
Old Oct 29, 2025 | 08:46 PM
Mark Kovalsky
If you want to do it yourself, get a manual from www.atsg.com. There are also some tutorial videos on YouTube..
Old Oct 31, 2025 | 12:56 PM
Shawn_Blankinship
8th Gear
Thank you sir. I appreciate your help.
brockstar2135
1997 - 2003 F150
Jun 18, 2022 07:49 PM
arizonasuperduty007
Arizona Chapter
May 8, 2012 04:55 PM
69cj
Nov 19, 2009 08:39 PM
